That rot product sounds fine to try if your cleaning up a few stumps from trees you cut down. Cheap enough. As i already said, If your trying to clear land your wasteing time and money. There is always a company out there who will market a product, that appeals to those on a budget as a magic cure to a difficult problem. Like a manual log spliter for $100 vs. $700 for a powered one that will work. And the torch product--how much LP to burn out a stump? This rot product is suited to a home owner with an established yard, and one who can burn legally without disturbing his neighbors with black smoke or paying another $30 to $50 for a fire permit or face a $200 fine. Plus can wait 6 weeks or more to try his first burn. Wood is poreous on its own, doesn't need anything added to it to absorb fuel or any liquid, but won't burn until dry or you get enough heat on it to dry it. I would think a longer time than 6 weeks with the soil keeping the stump bottom moist and away from oxygen. More like a minimum of 6 months in a warm climate. Joe's stump is already cut down and aged and may have termites already. That's differant than a fresh cut stump for testing this product to speed up rot and drying for burn. A small dozer can handle the size stumps the original post asked about to clear a lot for grass, farming or building and they cost less than a big dozer. Shopping around, probably would yield $40 an hour. For a yard, mechanical removal with a backhoe would disturb less ground. A stump grinder is more expensive and does less damage. Best to be sure the tree is dead before grinding or it can grow back thru its root system. If you have sink holes from roots, you have an extreme amount of termites in your soil. The roots are being eaten not rotting. Nothing rots quickly enough under ground to cause sink holes. I Have dug up roots perfectly preserved from trees removed from WPA city sewer projects many years ago during the depression. Some continue to grow and grow thru the clay based pipes of that era finding nutrition to survive, oxygen and water in the pipe. Acid content of soil and temperature are factors in rot, and what rots in one soil won't rot in another. Frozen ground gives you perfectly preserved roots, so a cold climate will slow any natural decay. Peaty soils and bogs will actually preserve, even a murdered body was found intact in a bog in Scotland. I remember reading they were able to discover the original wood fort remains from the first failed settlement in Jamestown Va. That's conditions for slow decay! We have finally heard about the burning device from Farmered. Some company always offering a magic bullet. Sounds like the aluminum welding rod they hawk at the county fair, then weld 2 soda cans together. You can't test the weld yourself or you don't think about it. Sometimes The hawker has a plant in the crowd who does "test" it and says it's super strong so you think its good. So some are convinced a $40 dollar set of rods can take the place of a $700 aluminum capable welder. Then they try it and the weld just pulls apart like poor glue. This interesting discussion will continue no doubt. A lot of stumps needing removing sounds like a need for land clearing. It's all hard work, and sounds like the LP burning device isn't the way to go about it cost wise. Original Question answered in my mind.
