Tool Talk Discussion Forum
oil change for mf-65
d bergman
08-27-2004 06:01:49
My husband recently purchased a 1964 mf65 tractor and wants to change the oil. He needs to know how much oil should be used because the dip stick is missing and he's having one custom made. Any help you could provide would be great. Thanks
Phil in MS
08-27-2004 12:07:44
 Re: oil change for mf-65 in reply to d bergman, 08-27-2004 06:01:49
This is likely not the best way to do this, but.
My MF 255 with a 203 Perkins diesel uses two gallon with out a filter change and 2 gal and almost a quart with a filter change. I know that the 165 uses the same 203 diesel but I am not certain about the 65. Tractor tips indicates the gas 65 is a 176 engine. It didn't give info on a diesel. I would suggest, if he plans on keeping this tractor, he contact a MF dealer and order the operator's manual, shop manual and parts manual. I would guess all three might run $100 or maybe $150 and would be money well spent if you think you want to keep this tractor. Good luck.
