Tool Talk Discussion Forum
welding machine
EB
08-26-2004 04:36:17
What woud make the ground clamp of a ac buzz box get so hot you can't touch it? Just started doing this
Big Jim
08-29-2004 22:16:27
 Re: welding machine in reply to EB, 08-26-2004 04:36:17
First place I"d look is the connection between the cable and the clamp. That area takes a lot of flack and, after a while, it comes loose or many of the individual strands break. Either way, it"ll get hot. If it looks at all doubtful, chop a couple of inches off the cable and remake the connection.
Ben in KY
08-26-2004 06:40:14
It is the result of a bad connection. Either the clamp is not making a good connection, ie dirty clamp or weak spring. Or the cable termination in the clamp is dirty/loose. Try cleaning it all up, etc and if no luck get a new ground clamp.
Kendall
08-26-2004 06:31:27
I recently noticed the same thing on my cracker box.
However I had just finished a project and havnet done any checking into it. First things I thought of were-
1) tighten screw that holds cable on clamp.
2) clean clamp where it contacts the metal 3) yank the cable and install a larger one.
4) buy a 200amp wire feed mig welder.
