Gotta whack you on one of your comments, my man. The Frigidaire is superior in my mind over GE. Without regard for anything else, the evaporator is mounted vertically on the rear of the box, has a large surface area (about as big as the box) and uses natural convection to extract the heat. It is up off the floor and requires no fan; the heat off it goes up into the room. The light bill is $10 per month noticably cheaper. The evaporator tray is also up off the floor, and is located on top of the compressor where compressor heat can aid in the evaporation process. Compressor is so quiet you can barely hear it run and it seldom runs. The GE has the (small) condenser crammed beneath it with the evaporator. All the "radiated" heat off it goes up to the bottom of the ref which has to ship that heat out eventually. It has a pull off exctucheon on the front to access (very limited) the condenser coil; which, since it sits 2" off the floor, is constantly clogging with lint; is most difficult to remove the lint and the motor gives out, probably due to the heat and lint. Air access is limited and as a result the compressor runs nearly constantly. It is noisy also. Sears Washer it the best in my book; has been for as long as I can remember. They just run and run and run and aren"t Maytag expensive, self cleaning filters and all. Been Married 42 years and had 3 Sears washers in that time. Nothing else and the latest one is over 10 yrs old, looks and runs like new. Had GE dishwashers for years. Not now. Have a Frigidaire. Bought a dishwasher ($199 Frig.@ Lowe"s) for the oldest son. Helped him install and check it out. Couldn"t believe how quiet is was, how well it washed and the ease of loading dishes and silverware. Went to Lowes and bought me one. Worst I had was Whirlpool; door seal problem. GE room Air conditioners are OK. Their spine fin is very efficient and no joints to fracture and leak. I have a 30" GE gas range that I like. Their small appliances have worked well for us. Don"t like their TV"s. Dat"s de history of my appliances. Mark
