Tool Talk Discussion Forum
Torque wrench accuracy
KCTractors
08-23-2004 20:11:47
How can one test the accuracy of a torque wrench?
JT
08-26-2004 13:10:10
 Re: Torque wrench accuracy in reply to KCTractors, 08-23-2004 20:11:47
I sent one out with our Matco dealer, costs $55.00 to get it done.
TheRealRon
08-24-2004 01:45:40
Any place that sells tools can refer you to shops that specialize in clicker-type torque wrench calibration. It costs about $30 and is typically done about once a year.
If a beam type doesn't show zero and the pointer is straight, the beam has been bent and the tool is junk.
george md
08-23-2004 20:28:52
KC, If you are wondering about a click type , put an 8 pt socket between the clicker and a beam type wrench and compare . The beam type are always accurite and clickers seam to always be off some. I have checked both on a torque wrench calibrator,beam type are always right.
george
msb
08-23-2004 20:24:19
Use a socket attached to a breaker bar and hook a spring scale to the breaker bar.Pull until a nut just begins to turn.Then check it with your torque wrench for a comparison.It won't be totally accurate but will be close. You can hook the scale at 1 foot from the socket or calculate the difference at other positions.Be sure to pull the spring scale straight(at a right angle to the bar) and not at an angle.That will give a false leverage on the nut being turned.You can also just use the spring scale on your torque wrench.
