Tool Talk Discussion Forum
Winch cable
Jackmcg
08-22-2004 09:04:16
I have an old Willys wagon with an 8000 LB PTO winch on the front. The 3/8" cable has been on it for well over 40 years. When pulled off the drum its so curly its almost unmanageable. Is there any way of straightening the cable?
Leland
08-23-2004 03:41:50
 Re: Winch cable in reply to Jackmcg, 08-22-2004 09:04:16
If you value life just but new cable. If this breaks while streached it will cut you or any thing else in half in the blink of an eye.I f you try to use this you are dumb or stupid!!
Mark - IN.
08-22-2004 21:13:40
Gone to the trouble of taking it apart (good move), spend a couple $ and replace it.
Lary E
08-22-2004 18:41:03
Don't be so damned tight and buy a new cable,only safe way to go.
TonyD
08-22-2004 12:30:02
Hi Jackmcg. You can make a cable straightener out of a piece of angle iron and a piece of flat bar. Some what like a paper cutter. You need to fabricate a hinge at one end of the angle iron and pin the flat bar, then weld a couple pieces of flat bar on the bottom of the angle for legs. The kinked cable will lay perpendicular across the angle iron, then you add down pressure to the flat bar in an attempt to kink the cable in the opposite direction. Good tool to have around. In this case please cut your cable into 1-foot sections and go buy new. I have been disabled for over 10-years now from using faulty rigging on the job. Please don�t take the risk. Like I tell everybody, it�s easy to get hurt, the hard part is the healing up!
ScottP
08-22-2004 10:14:20
You could try putting the cable under tension and leave it for a few days. You might get some of it out. Would be a lot easier and more reliable to replace it.
Scott
