Tool Talk Discussion Forum
FORNEY WELDER
thejdman01
08-21-2004 18:18:53
my cousin has a forney c-3 model phase 1 230 volt frequency welder. he lives in baraboo wisconson so i cannot go up there and look at it. he bought it on a farm auction for 100 bucks 20 years ago and when he bought it it was pry 20 years old. (not sure about exact age besides old). anyways doesnt matter worked real well for what he spent. anyways it stopped working and he asked me for any help. unfortunatly i dont know alot about forney stick welders and thought id throw it out there to see what you guys know. he said and i quote i dont know this is what he said so i cant help you any more then what i know "it turns on and i can hear it hum but it wont weld" "i check the cables for breaks made sure the ground is grounding etc" "i took the shield (back)off and nothing is black like voltae spike (basically nothing painfully obvious so he has no clue. i like i said havent and cant look at it and he"s not real sharp so any things that thaey are known for or any quick simple checks i could give him would be appreciated thanks alot
steve B
08-23-2004 04:43:02
 Re: FORNEY WELDER in reply to thejdman01, 08-21-2004 18:18:53
I had a Forney welder I picked up for 3 bucks.
It had the plug in amp settings and was pretty big. I think it also had a battery charger. Any way I gave it away. I called forney, which now supplies the hardware stores with abrasives and welding supplies. No more welders. What model do you have? I got an owners manual and wiring diagram I can send You.
Charles (in GA)
08-22-2004 19:27:18
And just because he can hear a hum from the welder doesn't mean that one of the two fuses isn't blown. It could have a 110 cooling blower off one side of the 220, or one of the fuses could be partially blown, still passing some current.
Charles
KX
08-23-2004 08:49:34
 Re: FORNEY WELDER in reply to Charles (in GA), 08-22-2004 19:27:18
I have 2 old Forneys, neither have a fan or blower
thejdman01
08-22-2004 14:44:45
ALSO DOES ANYONE KNOW WHERE TO GET PARTS FOR ONE? A GOOGLE SEARCH YEILDED NOTHING.
RickL
08-23-2004 12:34:46
 Re: FORNEY WELDER in reply to thejdman01, 08-22-2004 14:44:45
I have a forney welder for sale if that would help. It is another fellow who retired and asked if i could get rid of it for him. Should be here next week so Ican,t tell you model all iknow is it worked fine when last used. Rick
KX
08-23-2004 19:21:57
 Re: FORNEY WELDER in reply to RickL, 08-23-2004 12:34:46
Yes I"d be interested. Where is welder? Those old machines are awesome. If you have ANY need maybe you consider putting it in your shop but if not, no trouble finding it a home.
RickL
08-24-2004 05:55:25
 Re: FORNEY WELDER in reply to KX, 08-23-2004 19:21:57
KX; It is located in southeast Iowa. I have welder,plasma cutter,torch etc. I don"t need it. They don"t bring much around here anyway. Has always been in fellows shop,he also has a cutting torch outfit wants to get rid of also,it has the little small tanks. RickL
KX
08-24-2004 07:02:40
 Re: FORNEY WELDER in reply to RickL, 08-24-2004 05:55:25
Rick, sounds good especially "don"t bring much" but...they are too far away from me. Wish it was closer. THANKS
RickL
08-24-2004 15:58:50
 Re: FORNEY WELDER in reply to KX, 08-24-2004 07:02:40
Where are you located? I have shipped all over. Rick
thejdman01
08-22-2004 06:32:44
does anyone know where to obtain a wiring diagram i could pass along? i mean it cant be too complicated but if one was available it would be handy.
Charles (in GA)
08-21-2004 22:13:00
Hopefully your cousin is at the show this weekend and not home worrying about the welder. You should have used the show as an excuse to go visit and then you could fix the welder to boot!
Make sure he has covered the most apparent thing of all, that he still has current down to the welder and hasn't blown a fuse or had a 220 wire in the incoming cable break. There simply isn't much to go wrong with a welder.
Charles
