Welding patio furniture
Michael Az
10-21-2000 22:05:47
I wish to make some patio furniture with my Miller mig and was wondering if anybody has seen any books or web sites that may show the fabrication of such? Thanks---Michael
Jay P.
10-28-2000 20:40:45
 Re: Welding patio furniture in reply to Michael Az, 10-21-2000 22:05:47
If your heat bending tubing it is a good idea to fill the tube with sand first so it don't collapse.
Michael Az
10-31-2000 08:22:16
 Re: Re: Welding patio furniture in reply to Jay P., 10-28-2000 20:40:45
Thanks for the tip Jay
T_Bone
10-28-2000 04:07:35
Hi Michael, It will cheaper to buy a new set already made up than to build your own, but I know you got the I want too. So go to your local lawn & graden shop with a pad and pencil and take the deminsions off one you like and it will also give you the lengths to cut. For bending the nice looking curls, get a piece of 1/4" plate about 12"x12" weld a pice of 1-1/2" square tubing on the bottom side as this goes into a vise and place a 3/16"x1" sloted bolt size 3/4" in the center, then drill a series of holes at different centers away from the center bolt, in these holes make different size pipes to bend around, use 1/8" thick strap iron to make the curls from, place one end of the strap iron in the slot then bend around the pipe forms to get the proper radius. Either cold bend or heat bend around the forms, cold forming works really well. Also put a 3/4" bolt about 1/2" gap from the center bolt as this can be used for all tpyes of "off" bends or for straighting strap.
Have fun!! T_Bone
Michael Az
10-28-2000 08:16:02
 Re: Re: Welding patio furniture in reply to T_Bone, 10-28-2000 04:07:35
Thanks T_Bone for the advise. Glad you explained the bending fixture as I need to make one. Thanks again----- ---Michael Az
