Tool Talk Discussion Forum
Homelite XL2 Auto
Daryl
08-19-2004 10:31:04
Just acquired a Homelite XL2 Auto that has not been run since the mid 90's. I want to remove the gas & oil tanks. Is there anything special I need to know when pulling the rotor wheel? Can it be pulled without removing the housing? Thanks, Daryl
RWK in WI
08-19-2004 18:19:36
 Re: Homelite XL2 Auto in reply to Daryl , 08-19-2004 10:31:04
You remove the starter side of the housing by taking out the 4 screws that go from the starter side to the power side and remove the screw at the top of the handle bar. Then the starter side of the housing just comes off. If you need or want to take the power head out of the housing - remove the two screws on the top of the housing and the two screws on the bottom, remove the spark plug and the power head should be loose. Watch how the throtle linkage attaches as you will want to know when you put it back in.
I hope this helps you.
