Tool Talk Discussion Forum
Welding Rods Coat hangers
Tip
08-18-2004 19:18:27
I was told that coat hangers are fine for oxy-acetylene welding of steel - that they are very close to purchased welding rod. They seem to work abou the same..... what am I missing?
Thanks! Tip
Carm
08-19-2004 05:41:22
 Re: Welding Rods Coat hangers in reply to Tip, 08-18-2004 19:18:27
I too have been part of the coat hanger club. Works well. The coating will cause contamination though.
T_Bone
08-19-2004 05:04:25
Hi Tip,
The only problem with using coat hangers for filler rod is there"s a wide varation between metals used between mfg"s and you need the clean the coating off he wire.
That being said I"ve used both coat hangers and tie wire for filler wire on non critical welds. There"s also #9 wire for tieing bundles of rebar that works well.
Tie wire works great on auto body repairs.
Have you tried to gas weld AL, Cu, Pb, SS?
T_Bone
jakej
08-19-2004 09:19:42
 Re: Welding Rods Coat hangers in reply to T_Bone, 08-19-2004 05:04:25
After I get walking on water mastered I'll try to weld a 1 in thick X 12X18 copper plate with gas.
Tip
08-19-2004 07:32:17
I can do a pretty good job with mild steel, fake my way through aluminum, although I haven't done it enough to make it look pretty. I have never tried to weld copper, lead or stainless. I am in the process of repairing an 8n hood for a Funk conversion - been teaching myself body repair and having a ball. I picked up some hammers and dollies on Ebay cheap and have been "pecking" away.
I had aspirations to build an airplane - still do, but no time - and learned to weld in order to build the 4130 fuselage. Gas tanks are aluminum, so that was part of the "training". When my kids get older, I'll get back on it. In the meantime, I have access to a little Pitts Special, so I get to go upside and shake the cobwebs out whenever I want to. When the time comes, I am going to build a Pitts Model 12 - with a 360 hp russian radial engine.
Tip
Coloken
08-18-2004 19:28:58
Coat hangers have more carbon in them than bailing wire. I used bailing wire for most stuff but coat hangers worked fine when welding on Mauser rifle actions/bolts. Seemed to match the hardness. Don't remember who started me on this..an old time gunsmith I think.
