Hi Joel, I"m not going to be alot of help here as I don"t have a copy of a Case WPS (welding procedure specification). It"s not the old metal I"m concerned with but the new stub material. I also have never made this repair myself so if someone would chime in with some experience that would be helpful. Metal alloys have taken a path all there own and there"s no more "standard" mix so you don"t really know what your dealing with, without asking. You might contact Case and see if they have a WPS and follow that and disreguard all my info other than techinque. Generally speaking, I would preheat too 500� (lead wheel weight melts at close too 500�) then weld with 7014, 7018, 6011, 6010, 6013 (in that order) for AC, then postheat too 1200� and let cool slowly. I"m assuming the stub is high carbon and thats why the postheat treatment. Follow this reguardless: Cleaness can"t be specified enough. Preclean the joint with a grinder well out past 1" of weld center line then preheat then chip weld, then grind each pass to sound metal while paying close attention to any slag inclusions. Don"t, DO NOT, leave "ANY", nada, zippo, zilch, slag between passes. Grind as deep as you need to remove slag. If your having to remove too much weld then grind a slot, weld, then grind another slot, weld, etc;, just don"t leave behind the slag are you will most likey will have a weld failure. Although the 60 series electrodes are not my first choice they can be used for this type of repair. 6013 has such a heavy slag build up thats it"s very easy to trap slag with-in the weldment and is why it"s my last choice. T_Bone
