Tool Talk Discussion Forum
Straightening an Axle Shaft
TwinCreek
08-18-2004 06:25:48
I need to try to straighten an axle shaft from an old ATV. It has a slight bend near the end. A replacement is hard to get and expensive. It is a hardened axle and should not be heated to bend. Should I try to use a hydraulic press or try hitting it with a big hammer? Thanks for your help.
nwb
08-19-2004 17:17:21
 Re: Straightening an Axle Shaft in reply to TwinCreek, 08-18-2004 06:25:48
I tried to straighten an axle out of a 2001 Blaster. I took it to work and put it in the press. When you let the pressure off it went right back to where it was. A friend at work took it to a local black smith for me,so I cannot give first hand information, but here's the gist of what he did. He chucks it in a lathe and heats it( I think spinning). Then he takes a big hammer and beats on it. Repeats the process until straight. I do know that he cools it spinning. I do know that he says it must spin cool or it will bend in the cooling process. My son has put a year and a half of hard riding on that Blaster and the axle is still holding. Look around for a local guy who is familar with this process and he can probably fix it. But from my experience you cannot straighten it yourself.
JMS/MN
08-18-2004 07:34:14
Use a press and two V blocks. You need a controlled situation- and whacking it with a big hammer does not provide that. Bend it slightly over center, release pressure, and either eyeball it or use a dial indicator to check for straightness while rolling it. If you went too far, just bend it back.
