Tool Talk Discussion Forum
Tekonsha electric Brake Controller
Sam MI
08-15-2004 05:17:22
I have this unit on my 1998 Ford F150. When trailer is attached there is a continous current draw. I.E. the green indicator light is on. Is this normal? When I leave the trailer attached for extended periods it drains the battery. I usually disconnect the trailer plug but sometimes I forget. The unit works fine otherwise. Thanks for any comments.
David Chell
09-05-2004 19:42:33
 Re: Tekonsha electric Brake Controller in reply to Sam MI, 08-15-2004 05:17:22
Has someone out there got a copy of the operating instructions for a Tekonsha Brake Controller. If so, would it be an imposition if I ask if you can scan and send it to me ?
Charley
08-16-2004 06:49:36
I had a Tekonsha brake controller on a 1989 ford gas burner and after a few years it would kill the motor when you applied the trailer brake. Traded that truck for a ford diesel and put a new Tekonsha controller on it. In a few years it would kill the diesel when it was idling and the brakes were applied. Never did figure out what caused this, but I switched to another brand of controller and didn't have any more problems. Anyone had a similar experience with Tekonsha?
TheRealRon
08-16-2004 03:31:34
Sounds like a short or parasitic drain in the trailer wiring.
john *.?-!.* cub owner
08-15-2004 19:42:16
Sam, I've used Tekonsha controllers for several years, and for the green light to be on when the brakes are conncted is normal. That is a sefety check so you have a visual verification. The current draw for this circuit is so low that you should be able to leave it connected for weeks at a time with no problem. It would appear that you either have a faulty controller that is applying a little current to the brakes, or your battery is bad. I used to do 2 way radio maintenance for a living, and would frequently run across batteries that would start vehicls good, but if they were left setting with even a small drain would go down rapidly.
BobCaesar
08-15-2004 08:06:36
I have two of them & both run the green light when the plug is in. Never had them run my battery down. I'd guess you have a drain somewhere else or you need a new battery. Call their "Help" desk! Good folks there and glad to help!
Van in AR
08-15-2004 07:02:28
Yes it is normal, the current draw is so little it should"nt run your battery down. Mine has a level control and a sensitivity control you can turn down and the light doesn"t come on until turned back up. However I have never left it hooked up and sitting for over a week at a time.
Van
Dozerboss
08-15-2004 19:14:29
 Re: Tekonsha electric Brake Controller in reply to Van in AR, 08-15-2004 07:02:28
I think i had a differant and older controler than yours. Here's a weird problem i had, that was hard to figure out as it would do it off and on. Mine was a 7 pin RV connector. The plug gasket at the rear failed and it would fill up with rain water and cause the same current draw. Not enough to blow any fuses, just a cross circuit from the water. It would also disable the cruise control and turn signal when trailer was plugged in--otherwise no problem or symptom. A good cleaning and silicone dielectric on the connections cured this hard to track down problem.
Michael_East_Texas
08-18-2004 21:04:44
 Re: Tekonsha electric Brake Controller in reply to Dozerboss, 08-15-2004 19:14:29
Had a very similar problem with my Dodge, only without the trailer hooked up. An intermittant 10 amp draw that would suck my batteries dry overnight. I suspected everything but the real cause.
Turned out to be, you guessed it, that 7 pin RV connector, or the G.D. Bargman as my friend calls it. Same as in your case with a slight twist. Years of fine dust and moisture had resulted in fine sediment at the bottom of the horizonally mounted connector, between the brake controller wire and ground. (My controller is a Prodigy.) When it would rain, this sediment became a perfect conductor for a 10amp draw that never blew a fuse. Same fix, no problem since.
