Tool Talk Discussion Forum
I've got gas......Need to cut one now..........
Indydirtfarmer
08-13-2004 10:04:34
Now hold on.....I"m talking about my cutting torch. I just bought a new outfit. I thought I knew the proper pressures for cutting steel. Turns out I"m a bit forgetful. I"ve already brazed a few things. Got that right. I just need the right pressure settings on the regulator, for the oxygen, and acetelene. Thanks. John
T_Bone
08-16-2004 07:26:43
 Re: I've got gas......Need to cut one now......... in reply to Indydirtfarmer, 08-13-2004 10:04:34
Hi John,
I only use one tip size, a #3, as it will cut 1/16" to 1-1/2" very nicely. Thats a pretty small tip and can be alittle hard to clean, (small orifices) but a good all around size.
Pressure is all in how you use your torch. Me I use 40psi/Oxy and 5psi/Acet when I"m away from my cylindersand control final pressure with my torch valves.
By that I mean I don"t depress my cutting lever but just a small amount. If I need to blow out some slag in corner then I have the pressure to do so.
On the bench, then I use 20psi/Oxy and 5psi/Acet. I very seldom need more pressure than this.
I only use a very lite pressure on the cutting lever. If your tip is clean then you will need less pressure. If your tip is dirty then you will need more Oxygen. On a typical cut I just barely have the cut lever depressed.
Repost of my torch tip cleaning:
A trick I use for accurate free hand cutting is using a sanding disc to knock off the heavy scale and then use a scratch awl for my lines. The line is very thin so it makes following lines very easy.
Another is to stop cutting when you feel your hands or torch get out of balance. When that happens, stop and reposition the torch then continue cutting.
The cleanest cut comes from a clean tip. After you clean all the orifice bores in the tip, fire up the torch and set flame for cutting, then depress the cutting lever and observe the flame.
There should be a long very "uniform" inner flame cutting cone. If that inner cone is not "very" uniform then your cut will be ragged just like the flame cone is and the back of the metal will have slag. Reclean the center orifice until it"s very uniform.
A cut with a clean tip will have a very smooth cut surface with very little (if any) slag on the backside of the cut. If either one of these is not present reclean the tip.
The center bore orifice can get deformed and the tip needs replaced or cut off. It"s really important to hold the cleaning file straight in the bore hole and just removing enough material to clean the bore to make the tip last a long time.
T_Bone
kyhayman
08-14-2004 21:32:21
I'm running 6 and 25 on a 2/0 cutting tip.
MarkB
08-14-2004 19:25:08
You really need to check the charts from your torch's manufacturer. Here's a link to charts for Smith Equipment.
Harrygoodwrench
08-13-2004 12:06:37
If you just got a new torch set there should be a chart on what pressures to cut or weld with. I'm lazy and don't do much gas welding but do a lot of cutting. I generally use 5psi acetylene and 25 psi oxy. I can cut up to 1/2" with no problem at these pressures, just easy for me to remember( 5 & 25).
For gas welding/brazing its a pretty much equal mix such as 5 & 5 or 7 & 7 etc. Just be careful of what psi you use acetylene. Look at your gauge, there is a RED zone at 15 psi. Acetylene becomes VERY unstable above 15 psi. Can't tell you how many shops I go into and see the acetylene gauge pegged. you would be surprized how many don't know the danger of fire & explosion at these pressures. Much physics involved to pressureize acetylene in the tank. read owners manual and weld safely. There must be some charts you can find at Victor, etc. Here is a link to Victor. Hope this helps. Link
VADAVE
08-13-2004 10:13:08
I'm using 40 and 5/6 for cutting up to 1/4 inch stuff. May be low though as i'm not blowing the waste out real clean.
bubba
08-13-2004 18:40:53
 Re: I've got gas......Need to cut one now......... in reply to VADAVE, 08-13-2004 10:13:08
Think 40 is to high.Its cooling the steel down.That is why it is leaving a poor cut.You want just enough oxygen to burn(oxidize) the steel.Once it starts to burn, you should be able to turn the acetylene clear off.
Right amount
08-13-2004 21:42:11
 Re: I've got gas......Need to cut one now......... in reply to bubba, 08-13-2004 18:40:53
Oxygen pressure depends on the size of your cutting tip. should have got info with your setup
