Tool Talk Discussion Forum
Installing a wood furnace.......Chimney trouble!!!
Grohl
08-12-2004 19:57:44
I live in a very old farm house just moved into it and since winter is coming and i do not want to pay for propane when i have a lot of firewood and saws and everything else already i want to install a a wood furnace in the basement of the house.....After inspection i discovered the brick chimney that runs up through the middle of the house is a piece of crap and i was wondering what i could do???? could i run some type of chimney pipe up the side of the house???? or is that a NO NO ????? I would really like to use wood to heat.....I dont have much money im on a very tight budget so any suggestions would be great
Thanks!!!
Leland
08-13-2004 23:31:42
 Re: Installing a wood furnace.......Chimney troubl in reply to Grohl , 08-12-2004 19:57:44
They make an bladder that you drop down chimney then inflate then pour morator in to from a new liner saw on this old house, seemed to work well. Or you could get what I am looking at an forced air stove that sits outside and some of them hold 4ft chunks and you only stoke once a day much safer and no smoke in house or ash.
Jared in VT
08-13-2004 11:19:53
Mr. Grohl,
No quick, easy answers here. You are asking to deal with very complex variables that only experiance can answer. Buy the book, (or just read the important parts in the book store): "Renovating Old Houses" by George Nash, published by Taunton press. He covers in detail your specific questions and how to "do it yourself". This book will save you pain and suffering and cash. You can line the chimney with tile and vermiculite and get by nicely this year until you can build yourself a new chimney. Forget wood furnaces, (if it was any good, why would some dude give it away?). Install a wood stove instead. Get the heat directly. Most self styled experts are damn fools and will turn you into one too and take your hard earned bucks in the process. Don't be scared, but don't be stupid either. Keep the new chimney inside the house so it will draw properly. Best of luck. Jared
Nolan
08-13-2004 10:58:08
Had that problem with my house, spent quite a bit of time researching and learning.
The stainless steel chimney liners cost $25 a foot, or at least they did a few years ago. Not hard at all to snake them down inside the old chimney yourself. Available at woodstove specialty stores near you. All manufacturers insist their metal pipe will withstand chimney fires without damage, but then also insist that the pipe must be replaced if a chimney fire occurs. They are all rated for a life of around 10 years or so. The latter is often times well buried in the fine print btw.
Insulating a lined chimney is an interested area with many different arguments and rationals.
There is the camp that says it's completely unnecessary. That the pipe will be fine sitting free in the old chimney That this allows some heat to get into the chimney and warm the house. That it allows the metal pipe to expand and contract. That if the pipe should leak exhaust gasses, they will freely exit up the chimney. That insulation may result in the pipe being crushed, particularly the lose vermiculite. Vermiculite packs down, and can crush the pipe at the bottom if the chimney is tall. Add in water if it can it into the chimney and you increase weight, as well rust issues, and if it freezes, the crush becomes more severe.
Those that are pro insulation are also of two camps. The liquid mortar and the vermiculite and other lose fills. Claims of sealing the chimney should the pipe leak, protecting the occupants from combustion gasses. Protection from vermin entering the chimney. Increased (or decreased) thermal conductivity to the old chimney. Ease of installation (particularly the vermiculite proponents).
Future repairs with either mortar or lose fill insulation is difficult to impossible. With the mortar, it's effectively impossible. The lose fill can be dropped out the bottom of the chimney and repairs to the pipe made.
Many chose to abandon repairs when the chimney has been solidly insulated, treating the insulation as the chimney. This does seem to work, but many of the mortars dissintegrate when in direct contact with the acids of combustion gasses.
So here's my story and decision.
My house has two 4 story brick chimneys internal to the house, one on each end of the house. One used by the oil furnace, the other by the wood stove. Neither is in any danger of falling down, but both have poor mortar joints. The woodstove chimney has a teracotta liner, but it was installed improperly with conventional mortar in the joints, which has all been eaten away.
I went with uninsulated metal pipe dropped into the existing woodstove chimney. The ability to inspect both sides of the pipe, the ability for gasses to rise outside the pipe should it happen to leak, the ability to make future repairs easily, and the cost of not buying insulation were all factors in my chosing the non-insulated route.
The choice of pipe I made was black stove pipe. The exact same pipe you use between the stove and the wall thimble. My reasoning was that this pipe is perfectly adequate as a chimney pipe, for that is what it is. It is not as long lasting as stainless, but it is cheap and easily replaced.
I installed it from the top, with the 4' sections screwed together. It was actually quite easy to do this job. The pipe is doubly mounted in that it sits on the 90 degree elbow at the bottom, and is suspended at the top from a rod going through the pipe and resting on the chimney top.
The total cost of my metal chimney liner is only approximately $100.
This has given me a secure metal chimney that I can (and do) easily inspect and clean on a routine basis. It has been in service for several years now, and has worked very well. I do have a CO monitor in the house, and it's readings have always been negligible during times I'm using the woodstove.
I did talk to my insurance agent about this prior to installing it. My existing brick chimney was legal and I was allowed to use it. As such, my lining the chimney was an enhancement to the already existing and legal chimney. The insurance representative thanked me for doing it, and as I recall, I got a small percentage discount on my policy for doing it.
paul
08-13-2004 09:06:57
I would let a pro at least inspect this, design it.
You can have a special cement stuff poured down thew chimney around inflatable tube to give it a real good lining.
You can line the current chimmney with metal.
You can put a triple wall metal chimney up outside the house.
That is best to worst options. If you really use the wood burner, you will save money with any of those options. Do this chimney thing wrong, and you will cost yourself a lot of money, & perhaps a life or 2.
Wood ash & heat is really hard on metal. You"ll be looking at doing it again in 10 years if you pick either of the metal options. Your call.
--->Paul
Jed
08-13-2004 05:46:20
I have a similar situation. Wait until you price triple wall pipe to run up the side. I have put mine on hold for now.
MarkB
08-13-2004 03:21:40
When we replaced the wood stove in our house, the installer suggested putting a liner in the chimney, as it was in fairly poor condition. Since we don't use the stove that often, we passed on the liner. I don't remember how much it would have cost for the liner, but I don't think it was too outrageous.
TheRealRon
08-13-2004 02:33:12
There is a time and place to save money but this ain't one of them.
Get a pro to look over the entire situation. I've seen installations like Pete mentioned. It meets code, is effective, and you better buy a winning lottery ticket! The pro might also suggest placing the wood furnace on an outside wall and running a class "A" (triple wall insulated) chimmney through the wall and then up on the outside, and then above the roof. This is not a perfect solution but does work. It also ain't cheap. There are other alternatives as well.
You may not realize this but a decent wood furnace, proper chimmney, and professional installation can easily eat $3,000 - $5,000 in a heartbeat. Anything less and you have a very good chance of burning the house down.
An alternative is an outside wood furnace. It pipes the heated water into your house and then you use an air handler/heat exchanger to move the heated air. Very safe but you'll spend $8,000 - $10,000 (installed) at a minimum.
grohl
08-13-2004 10:06:34
 Re: Installing a wood furnace.......Chimney troubl in reply to TheRealRon, 08-13-2004 02:33:12
I already have a wood furnace and everything i just need to hook it up... my chimney is pretty much screwed.....I like the idea of the outside woodstove i talk to one guy that had bought the whole unit and installed it himself and it only set him back 4,000....my buddy kinda wants one he lives in a trailer and thinks it would be much safer then a stove in the home itself....
Pete
08-12-2004 22:10:05
I don't know about your particular application but have seen a similar situation where a stainless steel chimney was installed inside the existing masonry structure. The voids between the masonry and steel pipe were packed with vermiculite. You need to talk to a professional in that field.
T_Bone
08-13-2004 01:05:16
 Re: Installing a wood furnace.......Chimney troubl in reply to Pete, 08-12-2004 22:10:05
Hi Grohl,
I"m with Pete as you can"t do this job on the cheap or it"ll kill your family in a heart beat.
Just think of a 6" flue on fire 14ft high burning at close too 3500�f at about 2000ft/sec.
Big blow torch huh! If the flue is not installed correct thats just what you"ll have, a huge blow torch!
I tried to tell my Dad how to install his flue and he wouldn"t listen to the "kid". The 2nd winter he burnt the rafters and wall studs out of the corner of the livingroom.
The inside stack to the thimble got so hot it melted the pipe. About $4k in materials alone and of course it was the wood stoves fault, not his :>)
T_Bone
buickanddeere
08-13-2004 07:19:34
  Installing a wood furnace.......Chimney troubl in reply to T_Bone, 08-13-2004 01:05:16
May get away with a stainless chimney liner? Either that or live in a 50F house wearing a sweater and heavy socks. Beats going broke or burring to death. One of the biggest problems with wood burning equipment is stoking the fire and operation of the draft/dampers. As throwing a stick of wood in the fire every 1-3 hours is a nuisance. The fire box gets crammed to the top with wood and the draft checked back until the fire smolders instead of burning clean. In the hopes of fuel only 2-4 times a day. If you want a stick of would to burn slower. Throw in a bigger piece that hasn�t been split. Burns far slower than a same size split piece. Now all that wood in a hot enclosed space with limited oxygen. The stove has turned into a wood gasification unit instead of a burner. The heat drives the unburned flammable gasses up the stack. Now that stack is loaded with creosote, may as well be coated with high temp grease. Sooner or later during very cold weather or when the draft is opened during/after fueling. The stack temp will rise high enough along with having available oxygen�����woof. Now that makes a blowtorch in the stack. The brick and firebrick will be heat stressed and perhaps crack. Steel will go soft by 1500F. And if that doesn't burn the place down perhaps the flying spark form the stack will ignite something else. I warned my father for years that flue draft limiting damper in the oil/wood furnace was chilling the chimney. Along with his over filling the fire box and closing the draft tight. Told me he'd been burning wood for 70+ years and he knew what he was doing. As the oil was rarely used, I jammed the oil damper closed and for years he didn't notice. One day he did notice and said it was there for a reason but when asked he didn't know why. I also made certain the existing smoke detectors worked and added a couple more. I didn't find out for weeks but eventually found out after I noticed he has removed the oil draft damper in place of a straight pipe. Then they admitted having the fire department out for a chimney fire. Afterwards & unknown to anyone I glued a couple of washer spacers on the unseen side of the draft control lid into the furnace firebox. This always allows some air in for cleaner combustion. And keeps them from over fueling the furnace now that the house gets too hot. The fire burns clean now with little noticeable smoke instead of a smoldering smudge pile.
T_Bone
08-14-2004 15:30:05
 Re: Installing a wood furnace.......Chimney troub in reply to buickanddeere, 08-13-2004 07:19:34
Hi BD,
Yep, same thing my Dad did, load the box with green wood with alot of sap, start the fire and dampen the flue as soon as the fire started.
This caused creosote to build up on the flue walls 1/2" thick and when the creosote caught fire it burnt off in chunks from the steam (not enough water at one time) then shot out of the stack like a cannon.
This is my 16th year on my current chimney. I awlays start a fire letting it burn as hot as it can get for the first 20min as this burns off any creosote build up from the previous day(s) use.
In 16yrs I"ve never had to clean the flue. I do take the chimney apart each year for inspection.
T_Bone
Fred OH
08-16-2004 08:17:47
 Re: Installing a wood furnace.......Chimney troub in reply to T_Bone, 08-14-2004 15:30:05
This subject came up at mom's house one day and my aunt mentioned that they always threw a hand full of salt in their stove once a week to take care of the cresote. Anyone else ever heard of using salt? I think I've heard old timers say they used something called brimstone. I haven't done any research on either of these...anyone else care to? Fred OH
paul
08-17-2004 14:20:24
 Re: Installing a wood furnace.......Chimney troub in reply to Fred OH, 08-16-2004 08:17:47
I too think it is way too corosive to putz with salt.
I"ve heard of putting an aluminimn can in the fire box every once in a while, have no clue if it actually does anything.
They make a product you toss in the flame every few weeks, one for wood, one for oil burners, to take down the coatings some.
--->Paul
T_Bone
08-16-2004 09:52:51
Hi Fred,
I would think salt would be super corresive?
Wood ash and water make lye so throwing in some salt should really eat up some metal...lol
There was a product called Red Devil or Blue Devil (I have no idea what it was) that looked like copper sulfate, that when added to the fire would also cause cerosote not to stick to the flue wall.
My kids like watching the flame when I added it as it would change the flames all different colors.
T_Bone
