Tool Talk Discussion Forum
penetrating fluid
Larry E
08-11-2004 19:37:01
I need something better than kroil,is there such a thing?
JT
08-12-2004 16:00:08
 Re: penetrating fluid in reply to Larry E, 08-11-2004 19:37:01
If there is, I would like to know about it. I have used a lot of differant things in the past, CRC, WD40, PB, Kroil all kinds of snake oils that salesman have brought into my shop, always go back to Kroil. I am gonna have to try Lelands idea, sounds like an interesting concept.The only thing I have found better so far is a smoke wrench, it works first time every time.
Leland
08-12-2004 15:52:25
Got in a bind 1 day mixed brake fluid and 2 stroke oil worked great ate rust
GMorrison
08-12-2004 11:58:49
Discovered ZEP45 a few years back. It was the original penetrant with teflon. Have introduced it to every place I've worked since, and everyone who's tried it loves it.
Gregg
Chris
08-12-2004 21:14:49
 Re: penetrating fluid in reply to GMorrison, 08-12-2004 11:58:49
I, too, like Zep 45. Only problem I have is Zep will only sell a whole case and only if you have an account. You got a couple / three cans you would be willing to sell? Let me know !
tech4
08-12-2004 07:45:52
I used PB Blaster on some brass fittings recently. After 24 hours I still could not free without destroying the fittings which there was no replacement. I added heat with a hair dryer, a real heat gun would have been better but after about 5 minutes of the hair dryer heat the connections broke free with ease.
TheRealRon
08-12-2004 05:20:28
Sure is, PB Blaster. Tried them all but PB is the only one I'll use.
Nolan
08-12-2004 05:11:00
You'll probably not believe this suggestion:
LiquidWrench- *WITH TEFLON*
I don't like liquidwrench. But the teal canned stuff with teflon is every bit as good as silikroil.
Where it shines is after you've gotten the fastener broken free. It "floats" the rust, letting the nut or bolt continue to turn without galling or jamming up on the threads.
How well do I like it? My gallon can of Kroil is sitting on the shelf where it's been for several years now. I've made the offer to give it away many times and never have had a taker.
Don A
08-12-2004 06:11:32
 Re: penetrating fluid in reply to Nolan, 08-12-2004 05:11:00
Nolan,
If you really do want to get rid of that can of Kroil let me know what shipping would be and I will pay you to ship it to me. D. L. Anderson
1371 South Hwy 99
Emporia KS 66801-7521
TGIN
08-12-2004 04:10:52
PB Blaster !!
George
08-11-2004 21:57:14
For what it is worth, I have had good luck with Gibbs.
Wayne
08-11-2004 20:59:34
Brian is right. We've tried them all and PB Blaster is the only way to go. Like any other penetrant don't expect it to work "overnight" if something is rusted tight, you may have to give it a day or so to actually penetrate and do it's magic. I've actually put 75 tons on a rusted shaft trying to get it out and it didn't budge. After hitting it with Blaster off and on over the course of 2 days I hit the end of the shaft with a 3lb shop hammer and it dang near fell out..... .A better testament to Blaster's ability I haven't seen..... ..
Brian in Ohio
08-11-2004 20:41:44
I've had very good luck with PB Blaster. It came through freeing up a stuck engine on a 10-20 McCormick Deering that I'm restoring.
TDK
08-11-2004 20:35:46
Not trying to be a smarta--, but the only thing I've used that is better than kroil is "heat".
