If they are the same as an 1150, here's how to remove the cast rim, and also how to move the hub on the axle. If you have power adjust rims and it will spin far enough out it would be easier to do that rather than taking off the dual.The dual is removed by driving the main tire(inside one)onto some boards to get the dual off the ground. Hook a chain around the rim, be careful not to get the valve stem, and lift the tire up a little using a forklift, loader, etc. Remove the 4 bolts, it will probably take at least a 3/4 drive and a large cheater bar, I think it takes an 1 1/8 socket if I remember right. You will probably have to spray some wd40 on the back side of the hub. You may even have to heat it a little. To pop the dual off once the bolts are out, Get a couple of bolt just like the ones that holds the dual on and grind a groove in them legnthwise( like a tap) . This will give a place for dirt to go. Take the bolts and screw them into the holes between the ones that the bolts that hold the duals on are. These two hols go through the rim and the bolts will push against the hub when tightened. You will probably have to work the bolt in and out to get it through the rim, it probably won't thread in easily from the dirt and paint. Once they hit the hub, tighten both of them evenly until the wheel pops off. To move the hub. Take a couple of chisels and hit them into the split. Once it is apart a little you can hammer the hub to where you want it. It will help to take some emery cloth and sand the axle smooth and get the paint off. When you put the dual back on you may want to use a piece of 2x4 to hold the hub where you want it because it may slide in a little if bumped. Also, coat the hub and inside of the rim and bolts with antisieze before putting it back on. Then if you need to remove the dual again it will come off MUCH easier, basically just a kick instead of pushing them off with the bolts.
