I have three basic circular saw configurations: 1. A 35 year old Craftsman 10" radial 2. A 25 year old Craftsman 12" table 3. A 5 year old Hitachi 8-1/2" sliding compound miter I use the radial no more than 5% of the time. About the only use it now sees is in some dado work and as a third set-up in a multi-saw usage sequence. Over the years I have found the radial to be too "finicky" in adjustments. Once the arm is rotated to a different position, accurate repeatability back to 90 deg is poor. I have never been able to correct this despite numerous alignment attempts done "completely by the book". The arm also has a little deflection in it which may or may not be a problem depending on what you are doing. Using it for accessory work with a moulding head is unsafe. Such things should be done with the correct tool -- a router or shaper. Depending on your usage, you may not need the big 12" miter saw. My 8-1/2" one will crosscut a 1"x12" board easily at 90 deg. And the angles are accurate and repeatable. Of course the miter saw does not rip nor does it do dado or sheet work. However, for most 2x and finish cross and angle cuts, it can't be beat. I started out with the radial as my only saw but if I had to decide my purchases all over again from the beginning, It would be a sliding miter saw and a table saw in that order, forgetting the radial altogether. If you do cabinet work, you need the table saw but the miter saw is an excellent addition to it and is actually better for general construction. My particular, all around usage is probably about 60% miter, 35% table and 5% radial. If I didn't have the radial, it would be more like 63% miter and 37% table. I would get along fine without it. The radial is great for doing multiple dados on long pieces such as sides to tall bookcases but that can be done with tools other than a saw -- such as a router, which is pretty much a necessity for a lot of cabinet work anyway. I guess I would summarize my opinion by saying that the table saw is king for cabinet work and the miter saw is king for general construction work. With those two tools, you don't need the less effective and "finicky" radial for anything. If you can have only one saw, then I suppose the radial would be an appropriate choice, especially if the price is right. However, a good used 10" table (if you can find one) plus a smaller-than-12" miter would be a better choice, IMO. Rod
