TimV
08-05-2004 17:56:51
Re: Welding rod to use in reply to T_Bone, 08-05-2004 16:33:12
Hey, bud--I figured you"d be around at some point in this discussion--it"s right up your alley! The only reason I suggested 6013 over 6011 is that amateurs such as myself (and I"m assuming Chester as well, but if I"m wrong, no disrespect intended) can start and hold an arc easier with 6013 than with 6011. I think that the first order of business is for Chester to figure out if his welder will hold an arc, then to worry about the niceties. By the way, Chester, if your welder has an amp control, try using somewhere between 70 and 110 for the 3/32" rod, and somewhere between 30 and 70 for the 1/16". This might not be exact, but it will get you in the ballpark. If it doesn"t have actual numbers on the amp control, then you"ll have to guess at it based on the highest and lowest values given in the owner"s manual or printed on the welder. If it has no amp control at all, then good luck--you"re gonna need it! By the way, our local hardware store carries 1-lb boxes of rods (plus larger boxes of course) in 1/16, 3/32, 1/8, and 5/32 in 6011, 6013, 7014, and 7018--I believe it"s "Forney" brand. Nothing fancy, but better than buying a 50-lb box of rods you can"t use! My method is to buy 1-lb. boxes, and if I go through a pound, then it"s probably worth buying it in larger quantities. Some common stuff like 1/8" 6013 I can buy by the 10-lb box without it getting old. Others only have a couple of rods used out of the original 1-lb. box.
