Tool Talk Discussion Forum
water hydrant
Doug
08-04-2004 08:17:52
The installation manual for electric fences says not to put ground rods within 50 feet of water pipes. I was planning on having water run out to my cattle pens using plastic (polyurethane) pipe for the runs with the metal hydrants. The current ground rod is just about where I want to put the Hydrant. Is that going to be a problem? If so, I don't get why one has anything to do with the other.
Dean Minnesota
08-08-2004 07:56:59
 Re: water hydrant in reply to Doug, 08-04-2004 08:17:52
I would be more concerned about lightning traveling down the electric fence line than anything else. If you have a cow or calf within about 4 to 6 feet or less, the electricity traveling down the fence can and will jump that distance and kill the animal. That would be my primary concern about having metal water pipes close to the fence too.
txblu
08-05-2004 06:03:58
Well, I do electricity for a living. I read the posts and they are reasonably accurate as long as they are giving PVC the insulation characteristics it deserves.
The point about the hydrant being a ground unto it's self is well taken; except I live in the south, and my standpipes are PVC with a brass hydrant sitting on top.
A fence charger may put out 5,000 volts, but the impedance is such that you are not at risk (less you have health problems...ticker) and it pulsates .
I have been trapped between a metal barn (on a ladder) and the hotwire running down along the side (on insulators) and got some really good whacks that hurt, but they weren't life threatening.....unless I fell off the ladder and broke my neck.
I put the ground where I want; heck with the Philadelphia boys.
Mark
paul
08-05-2004 11:45:01
 Re: water hydrant in reply to txblu, 08-05-2004 06:03:58
My neighbor put up a freestall barn a couple years ago, after the big stray voltage lawsuits in this area. Man, where there inspections & paperwork on the grounding system that building got! Far more than the real electrical wiring, plumbing, or the rest. He used miles of bare copper in that construction. Anything metal got grounded together in 2 seperate ways to everything else metal. Was a web of bare copper burried in the concrete. Had to be done by someone versed in stray voltage, had to be signed off by the electrical company which knew a lot about it, and signed off by the county inspector who knew it was important but wasn't so versed in it.
Power company was very careful to balance the load & deal with that issue - can really affect cattle as well.
I'm sure it's a lot of overkill & covering the lawsuit issue, but 'just' someone who does wiring for a living isn't even good enough any more for a livestock building..... :)
I just bought a heat-tube energy free waterer for $650 to give my cattle water over winter here in MN without electricity anywhere near the water area.
--->Paul
txblu
08-05-2004 11:48:36
 Re: water hydrant in reply to paul, 08-05-2004 11:45:01
How does that work? Long tubes stuck vertically in the ground and some liquid inside that circulates with conduction cooling/heating from the soil to atmosphere and back?
Mark
paul
08-05-2004 20:33:15
 Re: water hydrant in reply to txblu, 08-05-2004 11:48:36
Check the link, it's an insulated tube that goes below the frost line, earth heat comes up in the tube & keeps the small bucket of water from freezing - hard anyhow.
--->Paul
txblu
08-06-2004 06:03:49
 Re: water hydrant in reply to paul, 08-05-2004 20:33:15
Thanks
T_Bone
08-06-2004 07:47:07
 Re: water hydrant in reply to txblu, 08-06-2004 06:03:49
Hi Paul,
Wonder if a underground cistern below frost line with two stand pipes, one smaller diameter than the other, would also keep the above ground pool liquid at freezing temps.
Ground temps at 8ft are pretty stable year around at approx 50�
T_Bone
paul
08-05-2004 01:04:57
You don't need a lawyer on my account, but the fencer company sure did, and he made them put that line in.
Look up 'stray voltage livestock' or 'dairy' and read up on it. There have been several dairies that went out of business due to sick animals, presumably caused by very low currents that come out of the water system. Several power companies lost million-dollar lawsuits because of stray voltage from unbalanced lines & bad grounding near dairy barns. It's your livestock, and the fencer company is covered because they warned you - so do what you want. :)
However, all hydrants I know of are metal, so your setup is particularly bad - a ground rod near a metal hydrant both in the ground next to each other, with plastic pipe insulating the rest of the water system.
You very likely are a prime candidate for stray voltage. Cattle, dairy esp, are very, very sensitive to this.
--->Paul
TimFL
08-04-2004 21:18:21
I have to imagine that some where along the way somebody had to figure this out the hard way for it to be a topic of discussion. I pose the question; Why take a chance? Is 50 feet worth some one possibly getting hurt or worth the possible loss of production when the cows will not drink the water. If you don't install it as per the manufacturers instructions and something does go wrong, who is liable?
My $.02
MarkB
08-04-2004 19:48:58
I would bond the ground rod to the hydrant. That's standard practice and should eliminate any problems arising from a difference in potential between the ground rod and hydrant.
paul
08-05-2004 01:27:43
 Re: water hydrant in reply to MarkB, 08-04-2004 19:48:58
This isn't a human safety issue, so it seems to go against conventional wisdom.
The fencer ground & the water pipe will not pose a hazard to humans. That is not the concern here.
Unless you add a whole lot of bare copper ground wire to anything metal anywhere the livestock can touch, and properly ground _that_ wire somewhere - do NOT bond the fencer ground to the water hydrant!!!!
You will be making the stray voltage issue much worse. Humans don't even notice it - not an issue for us or a danger to us; cattle avoid it to the point of making themselves sick - won't drink until they dehidrate. Other livestock vary in their reaction to stray voltage.
Got me curious, looked up 'stray voltage dairy' & came up with many hits. Seems cows change behavior with as little as 2v at 2 mAmps, and 4 volts is considered a really bad situation. With the intense pulse of a fencer to 10,000v or more, I can see why they want such a wide seperation!
Check out http://www.msue.msu.edu/msue/imp/modda/
usda6960.html
--->Paul
buickanddeere
08-05-2004 05:26:08
 Re: water hydrant in reply to paul, 08-05-2004 01:27:43
You are correct. Never mix your fencer ground in any way shape or form with the electrical service and buidling/equipment/water system grounding.
Bob
08-04-2004 15:16:55
Livestock can sense EXTREMELY low voltages or leakage current, and will shy away from a water fountain or a feeder where they sense any small amount of electrical leakage.
This has lead to lawsuits against equipment manufacturers and power suppliers on the basis of lost weight gain, or lowered milk production due to the electrical leakage causing the animals to lower their intake of food and water.
I suspect the fencer manufacturer is practicing CYA by telling you to keep the fencer ground so far away from the water line.
Normally, it is safe electrical practice to "BOND" all grounds and water piping together, and this would seem to go against that.
Anyhow, the final "JUDGE" in this matter should be your State Electrical Inspector. Contact them, and get their "official" take on this matter.
JHesler
08-04-2004 13:58:42
Polyurethane pipe depending on the wall thickness has an electrical resistance of many millions of Ohms. There would be no measurable electricity coupling into the water even if you put your fence rod right on top of it.
TheRealRon
08-04-2004 14:54:33
 Re: water hydrant in reply to JHesler, 08-04-2004 13:58:42
Hydrants are made from metal and connect to the water pipe 4-5-6 whatever feet underground. The hydrant will then, acting as a the ground, make a complete circuit with a fencer on the fence. This is why they must be kept far enough apart so that no human being will be able to get a hand on each and get shocked.
rustyfarmall
08-04-2004 10:47:53
I always put up an electric fence to keep the deer and racoons out of my sweet corn, if I were to install the ground rod 50 ft. away from any water lines, I would need to locate it out in the neighbors bean field and I doubt if he would much care for that so I put it where it is handy, probably less than 10ft. from the water line. Never had a problem.
Mattlt
08-04-2004 10:11:55
They're most likely concerned with "stray voltage". Electric fence manufacturers have no doubt been called into court to explain why their fencers have (allegedly) caused stray voltage problems on dairy farms. They're just trying to cover their you-know-what's, by recommending 50'.
Stray voltage is a another can of worms...
While 50' might be a little excessive, I personally wouldn't recommend putting them right next to each other. Anything more than 6-10' feet should be sufficient. Depending on your soil type.
TheRealRon
08-04-2004 09:30:07
Polyurethane pipe? Really?
In any case, you don't need a lawyer or electrician or plumber. Obviously you have to move the ground rod anyway so move it say 6' or more feet away. As long as the water pipe is far enough away from both the fence and ground rod so that a person could not touch both at the same time, I see no problem.
Coloken
08-04-2004 08:58:31
Never ran into this befor. I think they are thinking that if the ground has poor conduction you "might" get some feed back if you touched a water pipe. Or to a waterer. Plastic pipe--?????. I would not worry about it. But, surly some here will tell you to be overly safe, check with your lawyer first, only have a professional install it etc. Couldn't pass up the chanch to get in that crack.
