I.H 240 utility hydrulic timing problem
Peter Tallman
10-15-1998 00:35:12
My I.H 240 utility has a prolbem with the timing of the draft control
The hydraulic valve that control the draw bar and draft control has a little arm that has a circle with teeth that fits on a piece coming out of the valve that also has teeth on it.
I've followed my T.A. manual and it didn't do much. I know I have to fit the arm on the rod
some certain place I just need a starting point. It is very had to explain. On each side of
the valve there are two arms and as the draw bar goes up these two arms move, one up, one down
this ingages the draft control when it gets to the right hight. I need help please. Thank peter
Dan Snyder
10-18-1998 07:33:29
 Re: I.H 240 utility hydrulic timing problem in reply to Peter Tallman, 10-15-1998 00:35:12
: My I.H 240 utility has a prolbem with the timing of the draft control
: The hydraulic valve that control the draw bar and draft control has a little arm that has : a circle with teeth that fits on a piece coming out of the valve that also has teeth on it.
: I've followed my T.A. manual and it didn't do much. I know I have to fit the arm on the rod
: some certain place I just need a starting point. It is very had to explain. On each side of
: the valve there are two arms and as the draw bar goes up these two arms move, one up, one down
: this ingages the draft control when it gets to the right hight. I need help please. Thank peter relax peter, I can help you, but I need to know if there is a cable going to your valve bank or if it has linkage going along the seat to control the height.
