Tool Talk Discussion Forum
Whats inside my tractor tires ?
RayS FL
08-03-2004 13:59:09
I need to take my front tractor tires off and have them replaced. They have water in them, but I have no way of telling if they also contain calcium-chloride. I bought this tractor 10-years back used and it never occured to ask the old gent what was in them. Most of the tractor places around here told me that they can put water in them if I want, but they do not want anything to do with tires that contain the additive (apparently its a bit corrosive). I want to drain these tires before I do anything with them, but I don't want to dump that stuff onto my well-drained sandy soil (this being north Florida). Is there any easy way to test a few drops to see whats really inside the tires (or inside the tubes if you will) ?
thx, Ray
shannon
08-08-2004 21:57:52
 Re: Whats inside my tractor tires ? in reply to RayS FL, 08-03-2004 13:59:09
Calcium chloride has a real salty taste.If green comes out, Do not taste it, could be ethylene glycol (Antifreeze) which can be "DEADLY" even in small quantities!!!!
John (MO)
08-06-2004 06:12:57
Squirt a little out and look at it and smell it. (I'm not sure that I would want to taste it!) You should be able to tell pretty easily if it's antifreeze. Ask around about what was typically used in your area around that time. Is freezing an issue where the tractor came from?
youngster
08-05-2004 14:37:52
Calcium cloride or cacl is road salt. here in ohio thousands of tone get dumped on the road in the winter and you are worried about 5 or 10 galons or it. sorry man it aint goin to hurt nothing but some grass.
paul
08-05-2004 00:55:20
While CC does kill vegitation because it's salt, it's not bad for the enviornment. Just a fancy salt.
However, if some knucklehead put antifreeze in the tires, then it's toxic and a hazard.
I need fluid in front on one tractor for weight, as it picks up some big loads on the 3pt. Another tractor I need to fill the rock box full, or it would need fluid. Even pulling the plow will make these 2 tractors real light, the fluid filled one will rear up on me once in a while on the right conditions.
--->Paul
John O (MI)
08-04-2004 04:58:45
I've been told that calcium cloride is what my local road crews spray on the dirt roads to keep the dust down. If this is true, you don't need to worry about dumping a few gallons on the ground. It will kill plants though, so keep it away from your lawn.
-John
Jon C -Florida
08-04-2004 04:30:05
Ray -
I dont think calcium chloride is too much of an environmental threat especially in such small quantities.
If you dillute it with plenty of water you should be o.k., assuming you don't put it directly on your favorite flowers or floritam grass.
Shane
08-03-2004 19:21:03
Get just a drop on your tongue and you will know if it has CaCl! Salty salty! Not sure how to properly dispose but I know I had a leak in the yard once and the grass died! Don't think you really need fluid in the fronts unless you are on steep hillsides.
OldTractorGuy
08-03-2004 15:49:37
Taste it. CaCl/H2O tastes like salt water.
