Tool Talk Discussion Forum
Craftsman Radial Saw Model 113.29460 arm locked up
John Little
07-30-2004 18:44:10
We have just bought a used 113.29460, and the arm itself will not release and swing to the left or right? Anyone have any luck getting this unstuck?
JULIO NELSON CONTRERAS
08-19-2004 07:57:35
 Re: Craftsman Radial Saw Model 113.29460 arm locke in reply to John Little, 07-30-2004 18:44:10
En colombia quien es el representante de esta marca
Keith-OR
07-31-2004 20:06:22
I would check the website that Mac posted on recall. I did in Jan and my saw was one of the saws on the recall list, filled out all the info on line. They sent me a new safer guard and TABLE TOP for my saw. Was worth the time to check....All free !!!!! ! just my nickles worth
Keith
ezyed
07-31-2004 13:44:18
My sears saw has two locks one is the lever that you lift and the other is a screw that tightens the clamp on the back side.
John Little
07-31-2004 16:16:19
 Re: Craftsman Radial Saw Model 113.29460 arm locke in reply to ezyed, 07-31-2004 13:44:18
Thanks for everyone's help. We finally got it working after trying the ideas listed here. We appreciate it!
MAC,IL
07-31-2004 07:55:45
John: food for thought,
Link
Some of these 113 models were subject to recall. Made by emerson elec. They will send you a free upgrade kit if it has not already been done. Easy to install. Might want to check into this, for user safety.
MAC,IL
07-31-2004 06:37:40
Other comments have you covered. Get some PB blaster or Marvel oil and let it soak a few days.
Those things are tight anyhow so you very well may have rust. Also when you pull the locking lever out, you have to pull it all the way, mine is sort of spring loaded.
RusselAZ
07-30-2004 23:52:27
Take the cap off the top of the post. The one that has the three screws in it. Then you can see if it the arm is rusted to the post. If it hasn't been moved for a while and you are in humid country it probably is.
The whole arm pivots on the post and both are cast iron, Least my 113.29401's are. These are machined to a close tolorance so be patient while the penetrating oil works.
Steve from TN
07-30-2004 19:50:44
Hey John, mine has a little lever out on the very end of the arm. I have to pull it out all the way to swing the arm. I do not know my model number; it a 10 incher.
John
07-30-2004 21:02:19
 Re: Craftsman Radial Saw Model 113.29460 arm locke in reply to Steve from TN, 07-30-2004 19:50:44
Yes, we have tried that. It pulls out just fine, but it is still locked tight.
