Hey Steve- U.S. Alloys (welding results)
MikeH-Tx
10-16-2000 12:04:40
I got a chance to try brazing the broken manifold with the rods I bought from your company. Worked like a charm. And this was my first attempt with welding cast iron.
Thanks!
MikeH-Tx with picture
10-17-2000 19:44:37
 Re: Hey Steve- U.S. Alloys (welding results) in reply to MikeH-Tx, 10-16-2000 12:04:40
Just fyi. Here is the manifold that I was playing with. mh
Steve U.S. Alloys
10-17-2000 05:32:31
Hi Mike,
Excellent. The welding Gods are smiling.
Steve
F14
10-16-2000 18:19:12
I sorta followed that discussion when it came up, but I've lost track. What rod and procedure did you wind up using? What condition was the manifold in (other than broken, I mean ":^)
MikeH-Tx
10-17-2000 06:25:00
 Re: Re: Hey Steve- U.S. Alloys (welding results) in reply to F14, 10-16-2000 18:19:12
Paul, a windy reply:
I am much better with oxy-acetylene than stick, so I used brazing rod #526fc. I bought two pounds, but only used one stick to complete this job!
The manifold was in very poor condition. I was prepared to throw it away and use this as a learning exercise. First I wirebrushed the manifold as clean as it would get. This produced a hole in the casting as well as the broken end of the exhaust section. Still, nothing to lose so I kept going.
I used the bench grinder to grind off the edge all around the broken piece, producing a place for a bead to form. Then, I clamped the broken piece into place and put the whole thing into a vice.
Next, I used the torch on very low heat and heated the entire manifold to 315 degrees (Just kidding. Got it hot.) Then, I welded, without regard to anything special. The rod wetted the metal pretty easy, particularly if I rubbed extra flux on it first. Fixed the break, fixed the hole.
When done, I put the torch back onto low heat and kept the entire manifold hot for five minutes or so, lowering the heat gradually. Then, I turned off the fan I was using in the shop for exhaust and let it cool as slowly as possible. I did not follow Steve's recommendation to slow cooling further by immersing into a sand bath.
Lastly, not welding related, I painted the manifold with rust converter, then painted with hi temp gray. Looks good! I'll toss a pic to you tonight and brag about my handiwork.
