Tool Talk Discussion Forum
need a spur gear
Harley
07-29-2004 12:59:59
I am looking for a simple spur gear for an 13x48 Turnmaster lathe. The company has told me it would be very expensive and to look for it elsewhere. I measured the gear it is 5.750 diameter .600 wide and has a 1.375 mounting hole. The number of teeth is 96. I can modify the mounting hole and width as long as the diameter and teeth count are correct if I can find something close.
The gear had a 1/2"ring of plastic teeth with a steel center, I'll take aluminum or whatever else I can find it in.
Thanks
Harley
Dean K
07-29-2004 21:18:25
 Re: need a spur gear in reply to Harley, 07-29-2004 12:59:59
Looks like std, but this is a link I made a while back for metric ones,
Link
Bob
07-29-2004 14:39:47
Have you checked with Boston Gear?
