Tool Talk Discussion Forum
Cushman chuck for turning lathe
Lavoy Wilcox
07-29-2004 08:32:08
I have an an old Reed-Prentice turning lathe with a Cushman 3 jaw chuck. The jaws are getting worn, and are no longer true. Is it possible to find replacement jaws, or am I out of luck? It is a 12" chuck, so buying a new chuck would be really spendy I would guess.
Lavoy
jake
07-29-2004 10:30:56
 Re: Cushman chuck for turning lathe in reply to Lavoy Wilcox, 07-29-2004 08:32:08
Theres a truing ring on ebay item #3829889487. Its for a 8-10" lathe 2 days to go currently $15.00, shows what they look like.
jake
07-29-2004 09:16:27
The jaws can be trued up by making a jig that goes over the jaws that prevents closing but allows a small grinding wheel mounted on the cross feed to true the tips. A Dremel can be mounted to the crossfeed easily just take light passes and it will be as good as possible.
Lavoy
07-29-2004 09:27:57
 Re: Cushman chuck for turning lathe in reply to jake, 07-29-2004 09:16:27
A friend of mine said he has a tool post grinder that I can use to do just that. What I wondered though is the jaws wiggle a little in and out, and didn't know if it would really work or not.
lavoy
jake
07-29-2004 09:46:28
 Re: Cushman chuck for turning lathe in reply to Lavoy, 07-29-2004 09:27:57
Thats what the jig is for found an example at the site below[searched for "truing chuck jaws", search tips and tricks
