Tool Talk Discussion Forum
THREE PHASE ROTARY CONVERTER
Larry in Tn
07-27-2004 18:19:49
Any advice/comments on 3ph homebuilt converters using 220/440 three phase motor as the generator??
Loren P.
08-02-2004 13:09:10
 Re: THREE PHASE ROTARY CONVERTER in reply to Larry in Tn, 07-27-2004 18:19:49
Check out www.andersonconverters.com. Two years ago I purchased a 3HP rotary phase converter panel from them, and it has worked very good for running a Bridgeport and a small lathe. They sell the panels on Ebay as well. These are self-starting converters. All you need in addition to the panel is an aditional 3 phase motor to generate the third leg. I think I paid about $120 at the time for the panel, and I got a used 3 phase motor from a friend for free. I looked at a lot of information on building a converter, and this was by far the simplest and safest.
The panel is sealed with all the capacitors inside, and has an on/off switch mounted in the panel. Once you get the panel and a motor, all you need is wire cable from the power supply to the panel, from the panel to the converter motor, and from the panel to the machine motor. There are electrical boxes attached to the panel to make the connections. I wired mine with a plug on the cable from the converter panel to a 240V single phase outlet, as this provides for a disconnect. I just plug in the converter, flick the switch on the panel to start the converter motor, then turn on either machine.
tech4
07-28-2004 09:41:58
My nephew uses a home made 3 phase rotary converter in his grain bins that has been working for 15 years or better. This was wired by a farmer-electrician that used all the same color wire and it is hard to trace out the circuit. If you are just trying to run a shop tool of some kind there are the electronic converters which are not cheap or the home or farm made rotary converters. You can find a lot of plans on Google by searching for build your own 3 phase rotary converter. One site is listed below.
Mike M
07-28-2004 05:11:13
I have one of those little boxes that is sold as a phase converter got it from Wholesale Tool they don't cost much and it works fine for my mill or lathe. They also sell the rotary type for heavy duty uses.
Bus Driver
07-28-2004 04:36:22
The VFD outputs a true balanced 3-phase with square wave, motors do fine with that. The one drawback to VFD is that one unit will power only one motor at a time. The use of any type of motor-powered convertor, especially the homemade ones, means that the motor used is drawing power all the time the convertor is running and that power will be at least 75% of the nameplate amperes. Runs up the power bill and leaves less electrical capacity for operating other things. The VFD consumes only a few watts within itself.
david
07-27-2004 21:14:09
I recently built a homemade converter with a friend out of a motor as you described. It worked very well and feeds a 3 phase panel so that he can choose what equipment he wants to feed from the panel.
It depends on how much HP you need... and how many applications you need to run. You may want to consider a variable frequency drive (VFD) on the piece of equipment you want to run if the load is not too high. It provides great control and electrical protection. you can even get them as a single phase input with 3 phase output.
george md
07-27-2004 20:53:36
Larry, There is nothing like true 3ph , roto-phase is
close but expensive. I use a reliance electric mfd
unit and it works quite well . It uses a coil in series with one phase to get a slightly lagging
phase shift and capacitors in series with the 3rd
phase to get a leading phase shift . there are 3
coils in the unit , splice in the amount that you
need to balance the load you are going to run, do
the same with a running bank of capacitors to balance. The starting current thru the #1 coil
pulls a bar in to connect the starting bank of capacitors. I use a slave motor with it but is not required , slave does not need to be started
manually. Slave is 5 hp and I usually don't use
a running bank with the slave set up just the starting bank.
System has worked well for more than 30 years , I
run every thing in the machine shop except the air
compressors on the system. 3 lathes (one is 26inch
swing) , 3 milling machines, a horiz boring mill(
3 inch lucas), a 14 x 48 cyl grinder ,planer,
bridge cranes. george
buickanddeere
07-27-2004 20:20:42
Ask 10 people and you will ten similar but different answers on this one. A 240/480 three phase motor can be supplied with 240 single phase and produce a "sort of" three phase power. For starting the "convertor.The motor shaft will have to be spun up with your boot or an electric motor if phase shifting capacitors havn't been added. In any case true 120/240/360 degree power will not be produced. A 0/60/120/180/240/360 with harmonics, phase and current shifts will be a result. Is it good enough? It can work well enough on equipment with light to modestly loaded motors and no sensitive electronics. If your home/shop service transformer also feeds sensitive equipment of your's or your neighbour's. The all sorts of mystery trips and failures can occur. Price out solid state variable frequency drives and true three phase generators on e-bay etc. Maybe able to drive a generator with a single phase motor depending on sizes.
Leland
07-29-2004 11:21:38
 Re: Re: THREE PHASE ROTARY CONVERTER in reply to buickanddeere, 07-27-2004 20:20:42
Hey b-ndeere I can't belive Ron did not tell you Guys you were all wrong.
buickanddeere
07-29-2004 11:42:54
 Re: Re: THREE PHASE ROTARY CONVERTER in reply to Leland, 07-29-2004 11:21:38
There is still time for that yet. Ron is busy selling calcuim chloride liquid ballast over on the tractor area of this site. I don't know why some people insist on loading a 50HP tractor with ballast like it was doing a 75HP tractor's work. And yet the tractor attached JUST to a 25HP load? Or those people who ballast a 50 HP tractor like it had 100HP and attach a load suited for a 100hp TRACTOR.
Leland
07-29-2004 12:16:21
 Re: Re: THREE PHASE ROTARY CONVERTER in reply to buickanddeere, 07-29-2004 11:42:54
I've mowed some real steep ditchs and was darn glad to have tires full of a heavy liquid to keep her upright. but I say to each their own You are right when you say tires last longer . And you don't heavy compaction either.
