Tool Talk Discussion Forum
Anyone ever Patent anything ?? or try to get one
Dave
07-21-2004 13:43:24
has anyone ever got a Patent or try to get one ??
is it real hard and $$$$$$$$$$$$$$$$$ to get one
Thanks Dave
db
07-25-2004 19:24:55
 Re: Anyone ever Patent anything ?? or try to get o in reply to Dave, 07-21-2004 13:43:24
Go to Link and buy a book called Patent It Yourself by David Pressman. It tells exactly how to do it yourself or how to get a lawyer. You'll know what a lawyer is talking about, and you'll know how to write for the Patent Office.
JeffE
07-22-2004 05:23:29
I've got 12 so far, a bunch more in the works...I work in a development lab so this my job...basically to come up with new ideas. I've done some things outside work also...sometimes it makes sense to get a patent, sometimes it doesn't, depends on the idea, business area, etc. You don't have to spend a ton of money to get one on your own. If you know someone who has been through the process they can give some advice. I suggest starting at the Patent Office website. USPTO.gov, and search to see if someone already has a patent on your idea, if there is, game over unless you can figure out a way to invent around the current patent. If not, find things that are similar and figure out why your idea is better than current solutions. Doing this yourself will save you $$$ from having a patent attorney do the searching, plus you learn more about what is out there. Next, you'll probably have to contact a patent attorney, show up with your idea and copies of the patents you've found on the USPTO website. This gives them a good start to write up the patent application, they will take it from there. I wouldn't contact any of the radio/TV guys, I think most of these are scams. Look in the yellow pages under patent attorney, talk to a few of them, ask about fees and go with someone you feel comfortable with. If you've got a new idea that may be of interest to an existing company you can show them the idea before patenting to see if they are interested....be sure they sign a confidentiality agreement so you still have the option to patent the idea. Also, write up the idea in detail and get a copy witnessed by someone, a notary is best. This documents that you had the idea and disclosed it the the company. I did this with a toy company (outside of my day job)... they sold a product, I got royalties without having a patent. There's a lot more to this, if you have more questions I'll go into more details if you'd like. Bottom line, patents are nice, they cost money to get, but there are ways to check out the marketability of your idea without first getting a patent and spending lots of time and money.
Neil
07-22-2004 00:02:23
One other thing that comes to mind:
The $10K to get a patent is spit in the ocean compared to what it'll cost to enforce it.
If I ever thought of anything that I thought was really good, I'd probably file the provisional application and then see if I could convince someone with deep pockets to buy the rights from me and be done with it.
Dick2
07-23-2004 04:53:09
 Re: Re: Anyone ever Patent anything ?? or try to g in reply to Neil, 07-22-2004 00:02:23
One of the manufacturing companies that I worked for deliberately infringed on a patent because they knew the other company didn't have the funds to defend the patent in court. So much for patent rights. Even if they'd gone to court and won, the royalties would never have covered their legal costs.
Neil
07-21-2004 23:46:14
One other thing I should mention:
Though it's expensive, it's not hard to get a patent. At my last job we got patents on at least 95% of the inventions we filed for. In fact, I can get you a patent on nearly anything if I specify enough detail in the claims to make it different from what has been done in the past. For instance, if there is something nearly identical to yours out there I might specify that your device is assembled with all left-hand threaded bolts and make up some reason why that's advantageous and get you a patent over that other device. Here's the kicker though, and the thing that some patent attorneys and a lot of the invention places won't tell you - the more details I have to put in the claims, the less the patent is going to be worth. The reason being that it'll be easier to design around. All a person has to do is use right-hand threaded bolts and they are around your patent.
The point is, while I can get you a patent for nearly anything, that doesn't mean that the patent will be worth anything (and a lot of them aren't worth a plug nickel (I've written a few)).
So, after you get your search, don't just ask whether or not you can get a patent - ask what exactly they think can be protected by the patent.
Neil
07-21-2004 23:29:36
Yes, I have tried to get 45 of them (for other people (I'm a patent agent)).
You will definitely want to get a good search before you lay out much money for anything else.
One thing you should know is that there is no deadline for filing a patent unless and until the device is used, sold, or published. Once one of those things happens you have 1 year to file either a provisional or a non-provisional.
So, one option, if you're not ready to lay out serious cash is to keep it under your hat and pursue protection later. And, while you may have made and used the thing already, experimental use doesn't start the clock running. And I'm sure any use you might have made of the invention to this point was experimental, right?;-)
As others have said, if you want to get things rolling one of the best ways to go about it is to file a provisional application, which will buy you a year before you have to lay out the big $$$ for a non-provisional. Of course, if you have an agent or attorney do all of the work on a provisional it's still going to be $1000. But a provisional application doesn't need to be any more than a reasonably-well written description of the invention with reference to some drawings. So, if you, or someone you know can write up a good description of it and you can find an agent or attorney that is willing to do just the paperwork of filing it, you could probably get a provisional app. filed for $200-$300.
Of course, filing a provisional app. will increase the total cost of the process if you go all the way through with it. And, obviously it will make it a year longer until you get a patent (discussed in more detail a little below).
Of course, if you file a provisional application, the thing you need to do next is make a concerted effort to find out how commercially successful the invention will be. That way, you'll have a better idea at the end of the year whether to lay out the next $3000-$10000 to have a non-provisional application filed.
Of course, one thing you need to remember through the whole deal is that the only thing filing an application (whether provisional or non-provisional) accomplishes for you is ensuring that if someone else files an application thereafter, you won't be prevented from getting a patent.
You have NO protection until the day the patent issues, which will be 1 1/2 - 3 years from the date you file the non-provisional.
If you have questions you can email me and I'll answer them within reason. I'd do the work for you on the cheap end of the range, but I'm pretty busy sending resumes out to people that would charge you a lot to do it.
Neil
DL
07-21-2004 21:43:52
Hey Dave,
I work in the Research & Development department of a nation-wide supplier of woodworking machinery & equipment... the company holds a couple dozen patents. I'm listed as a co-inventor on about six of these. I would have to agree with most of the info that's already been presented... expect to spend about 10 grand on the patent search and the attorneys to prepare the package for you. Most of our patents have taken 2 - 3 years to obtain. If you have a good idea and some time, money, and patience, chances are good that you'd be able to get a patent. Now, the bad news... a patent will do you little good unless you have some idea of how to MARKET your product. Just because an item is patented doesn't mean it'll automatically sell & you become a millionaire! As with some of the others, I've received absolutely NOTHING for my ideas and for all the work I've put into making those ideas marketable... other than my paycheck... But, I guess I do it because I enjoy the challenge of coming up with an idea and making it work. Another problem with patents is that, unless they're absolutely AIR-TIGHT, some other company will "rip off" your idea (maybe changing one little item) and sell the product anyway. Then, you have to come up with a legal team to pursue the offender... we've gone that route a few times... best we've come up with is a "cease & desist" order... little consolation for all the expense of litigation. I guess the bottom line is, (as someone else mentioned) a patent gives you "bragging rights" but, for most, is of questionable value. Good luck in your endeavours.
Regards, DL
Jake
07-21-2004 21:15:16
Check with www.clarkhoward.com
A couple weeks ago on his radio show there was some discussion about obtaining patents. There was some mention of a "provisional patent" that would give you time..... .... I don't know the details but try the website for starters.
Sierra
07-21-2004 19:59:57
Yup sure did and it was a three year process and cost around $3,500. NEVER use the inventor deals you see on TV and ads. Look for a good patent attorney and go with them. You will also have maintnence fees every few years and they can go to $1,700. Your pat. lasts for around 17 yrs. But if some one uses it you are the one to have to go after them and it can cost you much. I would never pat. again. I would go with a pat. search and see if it is viable and then if it is patentable, you have 1 yr to file for one or look for a buyer of your product so they can have the pat. rights. Cost less also. Good luck
PaMike
07-21-2004 19:51:50
My dad and I are both in the process of getting a patent. His is through his business. Cost him $10,000 and counting in legal fees and it been almost a year. I am getting one through New Holland for some work on a round baler I did when I was in college. I had to sign over the rights to them for the patent since I worked for them, but they paid me $420 for coming up with the idea. Yeah, you dont think that is much but since I was employed by them they have the right to it, so the money is just a bonus on to my weekly pay...basically unless you plan to aggressivly market your idea after you patent it dont bother going through the process. It is great bragging rights though...
Jon C
07-21-2004 18:05:24
A friend of mine did a patent on a tri-axle dump truck self-steering third axle. And my cousin patented something for the tool and die industry. Both were great ideas, and neither was implemented.
My sister was a patent attorney, and the amount of paperwork that has to be done is significant. Like the others said, its important to have an attorney that somewhat knows the subject. (Sis had a degree in electrical engineering and a masters in physics, and grew up in a farm family...so she has a pretty good handle on many things.)
Like Rick said, a patent search is one of the first things to do, and you would be amazed how many good ideas, that seem new, have already been done!
Russ Smart
07-21-2004 17:45:59
About a year and a half ago I was presented with a problem at work which I along with the head of my department found a solution for. I did the physical fabrication and he found some special parts and materials. After it seemed like it was going to work quite well he decided maybe we should patent it, because if someone else saw it and patented the idea, we would not be able to use it! I understand that the cost to our corporation is about $10,000 and it has taken 1 � years. Meanwhile we have signed lots of papers, one of which gives whole ownership to the corporation that we work for, which is normal, we WORK FOR them. I just thought I would share this with you. Like was said earlier, the first step is a search to see if it�s original, and remember you are dealing with lawyers that may have no idea what you are inventing! And watch out for scams!
Rick
07-21-2004 14:32:26
yes it is hard, it costs money, legal fees. Watch out for scam artists preying on your ego. Lots of people come up with ideas only to find out someone else did also, years ago. 2 of us invented this thing at work and the bosses said a patent was in order. We sent the idea to the company patent lawyers and a few months later the sent us a copy of the patent on the EXACT same idea, - the patent was issued in 1926!
Here is a link to the US patent office. Something you can do on your own is to search their databases for similar ideas. If you find yours there, then forget about it.
