Tool Talk Discussion Forum
Wire feed ?
Dean E
07-19-2004 19:59:52
Is there a rule of thumb as to the maximum width of a weld,when using a wire feed?I seen the one on arc welding,was wondering about wire feed. Thank you Dean Minn
TimFL
07-20-2004 22:06:54
 Re: Wire feed ? in reply to Dean E, 07-19-2004 19:59:52
More factors involved. Thickness and type of metal. Capabilities of welder, wire speed, amperage, etc. Type of wire. Your own skills.
As T_Bone said it is a matter of keeping the puddle molten. I have seen large machines put down 1.5 inch weld with half inch build up but that will not happen with a machine you plug into 120 volt house current
T_Bone
07-20-2004 01:58:14
Hi Dean,
Theres no weave restricktion on Mig solid wire using a shielding gas.
Using Mig innershield (flux core wire) or dual shield (flux core with cover gas) then yes there's a maximum weave of 1" width.
It's the slag cooling down between passes that were concerned with, that causes slag entrapment with-in the molten weld puddle.
T_Bone
