Tool Talk Discussion Forum
water glass
Larry E
07-18-2004 20:03:07
Is water glass or sodium silicate the stuff used to put in hotub to stop leaks?appreciate any info on this.
T_Bone
07-19-2004 14:24:35
 Re: water glass in reply to Larry E, 07-18-2004 20:03:07
Hi Larry,
Sodium silicate (egg whites) can be used for temporarly sealing a leaking head gasket but is no means a permanate fix and in fact will plug a raditor or block or water pump if not used correctly. I've used it on a couple diesel engines on a leaking head gasket.
Can also be used for a glue on cardboard.
I don't believe it's going to do a thing for your hot tub leaking. That would be much easier to reseal with silcon or plumbers putty (1st choice) if a leaking fitting.
T_Bone
Bus Driver
07-19-2004 04:40:00
The most important first step is to correctly and completely identify the material of the tub. Is your tub cast iron? I doubt that it is, but your question suggests that someone thinks that it is cast iron.
Larry E
07-19-2004 19:08:44
 Re: Re: water glass in reply to Bus Driver, 07-19-2004 04:40:00
Tub is fibre glass,piping is pvc fittings and and tubing.
Ben in KY
07-20-2004 08:56:06
 Re: Re: Re: water glass in reply to Larry E, 07-19-2004 19:08:44
If tub is leaking in the fiberglass, then a epoxy /fiberglass repair is needed. If leaking in the plumbing or aroung a fitting then Tbone has the right idea.
