Tool Talk Discussion Forum
Hydraulic Cylinder Repair
Joe
07-18-2004 04:41:14
My neighbor has several hydraulic cylinders that he has bent the rod on, and said I could have them if I wanted. I thought they would be relatively easy to take apart and replace the rod, but I haven't been able to track down any place where I could get new rods. Anyone know where I might find them, or has anyone had any luck straightening a rod after it has been bent? Thanks.
Rob
07-19-2004 15:47:10
 Re: Hydraulic Cylinder Repair in reply to Joe, 07-18-2004 04:41:14
I have made many cylinder shafts and saved others in a press. If the bend is very much I won't try any more after one broke and shot across the shop.
I would never heat a cylinder shaft. I make all sizes of rods, a shaft for a common 3" x 8" cylinder costs about $50.00.
kyhayman
07-19-2004 05:42:55
Almost all of the fluid power shops here keep bulk rod that they cut to length. I've been well satisfied with getting them to rebuild my cylinders when I need one done. It costs about 3 times what it costs me to do one but about a third the cost of new one. Since Ireally cant diagnose internal wear (so most of the time my repairs last about a year) seems like a good investment.
T_Bone
07-18-2004 19:10:02
Hi Joe,
As stated, depends on how much of a bend there is. I like to hot straighten the bend area as cold bending will bend again very easy.
To bend the rod, the metal grain structure has too stretch. Without heat the grain structure can not return to a normal state.
It takes alot of heat to preheat a 1-1/2" rod so don't rush the heating process or try to apply too much heat too quickly. Once the rod is a bright red to orange color then apply pressure to straighten the rod. You will have to press slightly pass center to allow for proper alignment because of spring back.
After you get the rod straight let air cool, then reheat too 1100� then quench in oil (makes the rod hard) then reheat to 500� then quench in oil (adds temper).
My loader bucket has about 100hrs on it after I straighten the rolling bend, about 3/4" off set. The new rod wipe seal is still good. It did ding the chrome finsh slightly that I had to use a 120grit emery cloth.
If I was going to work this loader bucket hard then a new cylinder would be needed as it's pretty difficult to get it perfectly straight with the tools I have and it makes alot of heat at the wipe seal as the cylinder works with-in the seal. For how I use my bucket it works fine.
T_Bone
JMS/MN
07-18-2004 14:28:55
Slight bends can be straightened with v-blocks and a hydraulic press. Not something you fix by whacking with a BFH. If overbent, just roll it over and rebend it. Use a straightedge to check your work. If not done correctly, the shaft seal will wear out early. Some are salvageable, some simply need a new shaft.
Steve-Maine
07-18-2004 11:54:05
I have a friend in Westbrook, Me who can make rods up in a day or so. If interested I can get you his phone number
Bob
07-18-2004 09:02:27
A local machine shop custom-makes new rods from chrome steel shafting. Probably too expensive for a common cylinder, by well worth it on oddball, out of production cylinders for special applications.
They also straighten bent rods in the press. The owner has quite an eye for it, and makes it look simple!
Whatever you do, it is important to have the rod STRAIGHT, or the piston will gouge the cylinder bore, and you'll get metal in the system.
Ron
07-18-2004 07:47:13
Sure, you can try to straighten the rods but they will wear the seals and eventually leak. New rods can be had but often cost about what a new cylinder costs, hence, the cylinders are worthless which is why he's giving them away.
Harold Hubbard
07-18-2004 05:54:26
I have straightened several rods with varying degrees of success, depending on the severity of the bend and its location. A sweeping bend over most of the length is fairly easy, a kink is about impossible. I always use a shop press, and the hardest part is to estimate how far beyond straight to push so that the rod will spring back to straight when you take the pressure off. I once asked a hydraulic shop about new rod material, and when they started talking about "dollars per inch", I bought a new cylinder instead.
txblu
07-18-2004 05:38:36
No.
Somewhat. 2x4 wood and heavy (15 lb or so)sledge hammer worked, not perfect, but good enough to function.
Put piece of wood on either side of ridge (hump up) on a concrete floor. Then one on top and give her a really smart smack. Will need to do it several times. If someone holds the board in place it will make it easier. The wood is hard enough to transfer a lot of the impact yet soft enough so as not to mar the shaft.
Be careful as things hop around when doing this.
Mark
