Tool Talk Discussion Forum
When to replace a tire ?
RayS FL
07-16-2004 10:22:11
I have a Ford 841 that I purchased about 10 years back. One of the rear tires was new when I purchased it. All of the other tires were used, but servicable. 10 years later, I'm beginning to wonder when I should replace those tires.
Front tires - 6.00x16 (7-rib) one still has some rib, the other has little or no ribs left on the center section. Both show signs of dry-rot on the side-walls.
Rear tires - 14.9-24 on 13" rim (13-24 4-ply) one tire is functionally new ( less than 250 hours ). the other tire has a bit of wear on the bars, but more importantly, is showing dry-rot on the side-walls and a number of 1-2" cracks there.
I am assuming that all these tires contain tubes. The front tires loose a small amount of air, and need to be pumped a little 2 or 3 times a year. The rear tires have (thus far) never needed any additional air. The front tires have water in them, and I think the rear ones do also.
After looking at the Goodyear and Firestone web sites, I do not see any 7-rib front tires, only 1,3,4,5 rib versions. Is 7 ribs required for this tractor ? I use the tractor mostly for bushhoging and lawn cutting.
Since the majority of the wear on rear tire appears to be dry-rot, how do I determine when to replace it ? Or is this something that can be repaired with vulcanization ? I read a little about that here, but not sure where or who to take the tire to to do that.
I can probably get the front tires off the tractor with no problem, but that rear tire has me a bit concerned (with respect to weight, etc). Are those tires usually pulled by the owner, or do you get the sales/service people to do it on site ?
thanks in advance, Ray
markct
07-17-2004 21:57:59
 Re: When to replace a tire ? in reply to RayS FL, 07-16-2004 10:22:11
well our theory has always been to run them till they dont hold air or ya can see the tube. i dont farm fulltime, just a bit of haying and brushogging and other assorted chores on our 20 acres. i remember when i was about 8 or 9 asking my dad when he was gona replace the tire on the back of his tractor that had huge cracks in it and a few chunks of rubber missing from the tread, he told me that it worked just fine for our purposes and had plenty of tread so why replace it since when brushogging you can poke a sharp stick thru a new tire just as easily you can thru an old tire, well im 21 now and that tire still looks just the same as it did then, still works good, may have a little less tread but thats about it, tractor tires are pretty tough so they can have alot more cracks than a car tire, and also if a car tire blows out it can be catastrophic at 65 mph but at tractor speeds its usualy pretty easy to control so theres not safety danger in old tires
Chris Jones
07-16-2004 22:07:58
My neighbor ran a front tire until the tube was bulging through about a quarter size hole in the tire!
The tread had been completely gone a long time ago--just cords showing all the way around. He drove it down the road like that. When he found the tube protruding he finally bought a new tire.
bcPA
07-16-2004 21:25:56
I would look around at auctions ect for a rim or rim with a ok spare. If I found a bare rim I would buy a new tire and tube and mount it and keep it as a spare ready to replace the dry rotted rear tire. Run the poor rear tire untill you discover a flat maker or till the poortire just gives up or till you get tired of using the old thing. It is nice for the old tire to find the stake or sharp rock rather than the new one you just put on a day ago. I personally dont care for calcium and perfer weights. Just my opinion. The fronts dont cost that much so If the expense is no big deal get a new pair, or if your on a budget or frugal run em till they give up.
Adam B.
07-16-2004 21:03:21
Sounds like you need tires. If you were just driving it a few times a year for no real reason, you might be able to nurse those along for a while longer. Since you use it, I wouldn't want to take a chance on having one go down out in the field (been there).
Your rear tire choice (if you can't get a match for your good tire anymore) should be a type R-1, or possibly R-1W. For what you use it for, R-2 would not give suitable performance (turf and industrial styles probably wouldn't be a good idea either). As for the front, 1-rib tires are for very specialized service and wouldn't be good for you. A 3-rib is more or less the old reliable design, and is a pretty good all-purpose. However, the 3-rib design is arranged so the center rib digs into the ground and gives better steering traction. That might not be a good thing if you're running over your lawn a lot, because you'll cut it up when you turn. A tire with 4 or more ribs that are all the same size would be better for you.
You mentioned you looked at the Goodyear and Firestone websites, which is a good start. Are those the brands that your preferred dealer carries? If you have Titan as an option, they make good tires and seem to consistently be even less expensive than Firestone's bargain tire choices. The Titan Hi-Power Lug R-1 would probably be a good tire for you, and I know it's reasonably priced (priced less than Firestone Traction Field & Road for my tractor). In your size, they have the Hi-Power tire in 4, 6 and 8 ply versions.
Like the others said, on-site service can carry a high price tag. Your tires are pretty small, so I don't think it would be worth the price of an on-site visit. If you have fluid ballast in the tires now, you should replace it when you get the new tires or figure out how much liquid weight there is and add wheel or suitcase weights as needed, should you decide to leave the tires dry. Good luck with your shopping.
Leland
07-16-2004 19:39:37
I would tire as long as possiable. but dont wait until it blows , take it to tire dealer. Bacause if you drive it in to shop you will save a BUNCH of money on service calls. Alone that would almost pay for front tires alone the good 6-plys . And as far as tires I don't know were you live but before fall harvest season ,most farm tire dealers have great sales on rears. But watch out who you deal with the shop I worked at prayed on every person that walked in door . So do your home work
JMS/MN
07-16-2004 17:41:56
If you are a hobby farmer and your livelihood does not depend on your tractor- wait until the tire fails. If you are not familiar with handling CaCl in the tire, expect to pay $150 or so for a service call for a simple repair that involves pumping fluid. Vulcanizing is designed for repairing a puncture- not the typical weather-checking found on tires.
Ron
07-16-2004 11:01:32
Dry rot = bad tire. I know, lots of people use them but they also get flats and they never happen at a convenient time. Most, but not all tires have tubes. Replace them with the tire. Don't worry about the rib count on the front. 3 ribs or more are fine. Worry more about the load range, especially if you do loader work.
If you have H20/CaCl in the tires, especially the rears, you don't want to fool with them without the proper tools and techniques. www.gemplers.com sells them.
If you live in farm country, tire dealers will bring a truck to your place and replace them for you. Have your checkbook handy, it ain't cheap! Depending on the tire mechanic, they usually leave the rear wheels on the tractor and change the tires in place. They also offer "calcium service" and can replace the H20/CaCl without spilling it all over the place.
You might also find www.millertire.com interesting.
