Tool Talk Discussion Forum
Model # of my bulldozer / adjusting the steering c
Armand
07-15-2004 09:01:05
I own an early international bulldozer for which I am trying to determine the model number. The prior owner painted over just about everything. I can make out the name under the paint. I beleive this dozer was made bach in late 1960 or early 1970. It has a blade that is only two way (up and down) with the hydralic's cylinder located up next/near the drivers seat. I am trying to fingure out how to adjust the sterring cluches.
Thanks
bcPA
07-16-2004 21:55:01
 Re: Model # of my bulldozer / adjusting the steeri in reply to Armand, 07-15-2004 09:01:05
get some solvent on rag and clean paint off the metal serial number tags, Maybee located where you could see it if your shins had eye balls. That is where my td9 int made in 1960 has the serial no. tag. Posting some pictures if you can would help. Some details are needed to help you. Such as gas or diesel How many cylinders turbo or non turbo. Does it have a gas and diesel fuel tank? Does it have spark plugs along with a diesel fuel tank? Dose it have a hand clutch or auto shuttle shift Ect.
