Tool Talk Discussion Forum
Aluminum tool box polishing
Fritz Campbell
07-13-2004 09:05:55
Along with my bed liner dilemma - I have been looking for an Aluminum tool box for the bed. I came across a nice used Weathergard Model 117 for sale pretty reasonable. Only problem I saw with it was that it is starting to get these white spots in the aluminum finish. It looks like they are under some type of plastic film. It where a way to polish or buff these white spots out? The rest of the box is cherry. Thanks for the help.
KJM
07-16-2004 20:07:34
 Re: Aluminum tool box polishing in reply to Fritz Campbell, 07-13-2004 09:05:55
Aircraft Stripper, it will take off the clear coat then you can polish out the bad spots and clear coat again or just polish about once a year to keep it shinny. 0000 steel wool works great for polishing. You can buy stripper at most auto parts stores.
Kendall
07-14-2004 07:57:12
Angle grinder with 8" spiral sewn cotton wheel. Start with black emery, followed by the Brown Tripoli. Hand finish with aluminum polish and you'll blind everybody with 2 block.
kendall
07-14-2004 08:18:06
 Re: Re: Aluminum tool box polishing in reply to Kendall, 07-14-2004 07:57:12
meant to say "followed by brown tripoli"
George
07-13-2004 16:01:01
Sounds like there might be a clear-coat type coating over a once polished surface. The coating is going to have to come off before you can get a uniform good finish.
Bob
07-13-2004 11:05:42
Talk to a trucker that keeps his rig polished up, or check at a truckstop for aluminum polish.
Fritz
07-15-2004 15:24:41
 Re: Re: Aluminum tool box polishing in reply to Bob, 07-13-2004 11:05:42
Thanks for the replies and the advice. I'll look into it.
