Tool Talk Discussion Forum
Anyone ever try this product? (Rust remover)
Roger
07-12-2004 18:45:23
It looks like it would be quite useful in the tractor/machinery restoration field.
Electrolysis made easy!!!
07-13-2004 22:52:50
 Re: Anyone ever try this product? (Rust remover) in reply to Roger, 07-12-2004 18:45:23
check out this website, click on restoration tips
I have used this on a 48 AC model "C"works extremely well. I now use the elctrolysis tank to remove rust on everything. CHEAP and EASY
http://www.fboerger.com/
Adam B.
07-13-2004 19:30:25
I'm in the process of using the POR-15 rust prevention system on my '39 JD B. (I didn't use their paint remover, I had the heavy dirt and old paint & scale that had to be taken off sandblasted off.) They have a heavy-duty degreaser that I only used a little bit of. The part I was pretty impressed with was Metal Ready, their acid prep product. The treated parts turned out much like the 'after' photo for the product you mentioned. Once wiped off, dried and coated with POR-15, it has an almost ceramic finish. I just have to do some assembly, then have it sprayed with their Tie-Coat Primer and topped with some JD Green and Yellow. It's supposed to be rust-free for life now. Time will tell.
Electrolysis is cheep too
07-13-2004 06:52:22
Try electrolysis to remove rust and paint. It takes a battery charger, water, and a piece of metal to use as an electrode.
Fill your container with enough water to completely cover your rusty metal. Connect the positive wire from the battery charger to the electrode piece of metal. Place the electrode in the water and make sure the two pieces of metal do not touch. Connect the neutral wire from the battery charger to your rusty piece of metal. Turn on your battery charger and wait a couple-three days. The rusty piece of metal wil probably be black. Shut down the charger, remove the blackened metal, scrub off with a wire brush, dry, and prime/seal your metal ... looks like new.
Oklahomatractorrebuilder
07-13-2004 21:04:21
 Re: Re: Anyone ever try this product? (Rust remove in reply to Electrolysis is cheep too, 07-13-2004 06:52:22
You forgot to mention the chemical to make it work right. It leaves you with bare metal without any black on the metal. Just be sure to wash it good after then prime as soon as dry. We use it all the time here on everything from sheet metal to a stuck engine.
Slowpoke
07-24-2004 00:57:10
 Re: Re: Re: Anyone ever try this product? (Rust re in reply to Oklahomatractorrebuilder, 07-13-2004 21:04:21
What chemical did he forget to mention? I thought washing soda was the right stuff.
Nolan
07-13-2004 04:56:09
Haven't used that product, but if you want a very affordable organic rust removal chemical, use vinegar.
