Port a band blade problem
ltf in nc
10-11-2000 20:11:06
My Milwaukee port a band has started having trouble with the blade "walking off". I have to make contact with the material prior to starting and I have to stop before exiting the cut to keep the blade on. The bushings seem O K. I do not have a book on the saw. Any thoughts
Greg Martin
10-13-2000 02:30:37
 Re: Port a band blade problem in reply to ltf in nc, 10-11-2000 20:11:06
I repair the power tools for a construction company and I have not successfuly fixed this problem, would like to know, I have changed the tires, bushings, guide blocks& bearings, swaped out the front housing to no help. If you have one fab tool , this is the one to have G.M.
Mark
10-12-2000 15:37:40
Those rubber tires need replacing after a while and the rollers that guide the blade have a small screw in them that loosens up. There is a tension adjustment under the idler wheel after it is removed. start with the tires there not much money. my two cents worth
T_Bone
10-11-2000 21:44:17
Hi ltf, I assume you have cleaned under the rubber grip gaskets and there in place. My front one rides up on the aluminum pulley, it's that one the center tee on the rubber, I figure I need to replace it as it keeps getting worse. You would think there would be an adjustment for alignment but I haven't looked too hard.
T_Bone
