Tool Talk Discussion Forum
arc starter
Iowa
07-08-2004 18:15:17
Is a arc starter on a 230 amp welder worth having? I have heard pros and cons but dont know if they are worth the money. Are they still available. I would like one for a Century AC DC welder if they work and are worth the money, about $80. thanks
T_Bone
07-09-2004 08:26:28
 Re: arc starter in reply to Iowa, 07-08-2004 18:15:17
Hi Iowa,
Depends on what your calling a arc starter. A HF unit is whats normal used for arc starting but you can't get a HF unit for $80, well I don't think you can as I have not priced them lately.
If your burning nothing but sticks then you need to take your thumb and fore finger and gently break off the flux from the end of the rod tip between passes. Just don't break off too much or the rod will stick easy with no flux 1/8" up from the tip.
If your having problems starting a new rod then your using too low of amperage or not striking the rod like you do a match or both.
If your using Tig then a HF unit can be a good add on componet.
Website of the HF unit or name and I'll take a look?
T_Bone
