Electronic ignition
harry holcomb
10-09-2000 17:02:47
looking for instructions to test ignitions with
a digital oscilloscope
Big Jake
10-12-2000 11:03:13
 Re: electronic ignition in reply to harry holcomb, 10-09-2000 17:02:47
heres a link that will get you pointed in the right direction--also check out all its links
link
IHank
10-10-2000 23:01:21
Harry- The analog scope is the best way to view ignition system primary and secondary circuit electrical activity.
There is no more "coil primary", "#1 spark plug wire", and "coil secondary", to hook up to. That stuff is all in the past... If you're wanting to deal with computer operated systems, get you the service manual on that particular system. It will tell you how to get the system to give you fault codes, as blinking lites on the instrument panel, that you can follow up on as to service actions.
Keep in mind that the fault code systems give information about stuff that a scope won't show.
Good luck from a former "Sun Man", IHank
ltf in nc
10-10-2000 20:12:56
A person by the name of Sean Straw that posts at the following web site is very knowledgeable with using a scope to accomplish the task mentioned.
[email protected]
