Tool Talk Discussion Forum
1949 Case SC foaming antifreeze in radiator
Rob G
07-06-2004 21:17:44
What would be the reason for the antifreeze to foam in the radiator?
George
07-07-2004 03:51:42
 Re: 1949 Case SC foaming antifreeze in radiator in reply to Rob G, 07-06-2004 21:17:44
Does this tractor have a water pump -- could be a shaft seal allowing air in. To test, remove drive belt and start engine. If, after the engine has warmed up enough to open the thermostat (if there is one), you are still getting bubbles, then your problem is either a blown head gasket or cracked block/head.
JDK
07-06-2004 22:30:18
Air bubbles in coolant are usually a sign that compression pressure is escaping into cooling jacket.Could range between a loose or unsealed headbolt,bad headgasket,all the way to cracked head or block.Not a "good" thing :(
