Tool Talk Discussion Forum
Brake drums, rotors and lousy parts stores.
James in North
07-06-2004 19:04:30
I replaced the brake shoes on my truck today and when I drove around, Advance Auto, Autozone and Napa all said they no longer turn drums and rotors. Well why the *ell not?
Then I asked if they could at least measure the drums and tell me if they were thick enough to use again. The woman at Advance said she didn't know how and that they had nothing to measure them with.
When I said I couldn't believe that, she said "We do have a tape measure, will that work?". And she said she'd been with Advance Auto for 10 years and she's still that incompetent!
The clown at Autozone couldn't find the measuring caliper and was more interested in cutting up with the other two loafers working there. By then I was so ticked off I went and bought a caliper and measured them myself.
So where are we supposed to get drums and rotors turned now? I'm sure not going to but new ones every time I change pads and shoes.
That's incredible! And what kind of auto parts store doesn't have a caliper to measure things?
I need to have a drink.
James
napaguy
07-11-2004 08:38:15
 Re: Brake drums, rotors and lousy parts stores. in reply to James in North Carolina, 07-06-2004 19:04:30
james, i work at a napa store..turned 6 rotors and 2 drums yesterday at work.how come you didn't just measure the drums yourself? they have the maximum diameter stamped on them. our lathe(accuturn) is eight years old. i am not sure we would buy a new one if this one went south....at 8 bucks a rotor it takes a lot of them to pay for a machine that costs upwards of 6000.00. we sell at least 4 sets of rotors a day. i can remember when we didn't even stock them. now we keep over 250 sets in stock..most newer vehicles do have throw away rotors..cheapest ones i have sold are for ford escorts..dealer cost is about 12.00 each.and for wayne down the way...i consider myself neithe a liability to my company or an idiot..... napaguy
Tim
07-09-2004 09:22:39
If your rotors are warping prematurely your
problem may well be not properly torquing your lug nuts. I discovered this problem after having problems with a Saturn. The rotors
are so thin now that over torqing or uneven
torque of the lug nuts not only causes the
rotors to warp it also will make your car behave
as if a wheel is bent. I use a torque wrench to 50 ftlbs in a star pattern then follow up
with the manufacturers torque specification.
I have heard it is necessary on some of the lighter autos to go even less than the recommended torque.
Kevin
07-08-2004 20:12:07
We fight rust around here. The last pair of rotors I had turned were working well until the thin metal vents rusted through. Having a rotor shatter is not something you want to experience!
These days I throw new pads on at 50k before major wear happens, then run 'em down to rivets and put new on at 110-120k. Drums and shoes are lasting 150k+, so if and when needed, they get all new. Won't ever bother with cutting again!
Ben in KY
07-08-2004 11:32:29
Just commenting on turning drums not rotors. If you have your drums turned you also have to have your shoes properly arced for the larger diameter drums or you loose most of your braking power.
wdTom
07-07-2004 18:11:56
The reason you can't turn rotors, cars and all vehicles for that matter, are so cheap is that when people have to buy a new rotor or pay for someother thing that they shouldn't have had to they don't go to the dealer and GIVE HIM &^%%. If enough people hollered they would listen and make things easier to service,and serviceable.
buickanddeere
07-08-2004 05:43:21
 Re: Re: Brake drums, rotors and lousy parts stores in reply to wdTom, 07-07-2004 18:11:56
Anyone who repairs thier own stuff is a very small segment of the market. Manufacture's 1st priority is to keep the dealers in business. Selling the vehicles doesn't make money. The service dept keeps the dealerships cashflow out of the red ink.
Wayne
07-07-2004 20:17:13
Hey James, I don't know where in NC you are, but the NAPA in Harrisburg (near Lowes Speedway) still turns the rotors. I don't think anybody is doing drums anymore but I know they still do the rotors. You used to be able to get the drums turned for big trucks, but nobody is doing that anymore either. Like one post said the new parts are simply too cheap to make it practical anymore in most cases. Then you also have to look at the idiots these parts places have working in them and factor in the liability issue.....you can get the idea here right?....
bob
07-07-2004 12:57:57
My mechanic wont turn rotors, and some manufacturers dont even recommend it. If they warped at factory thickness they will warp sooner when they are thinner. Most rotors and drums are so cheap now its not worth turning them. I now people are ragging about Autozone and they do sell some junk,but I bought new rotors for my 2000 Ford Ranger and they have lasted longer than the factory ones.
Bryan
07-07-2004 12:42:34
I still turn rotors here in my shop. In fact I even check new rotors to make sure they are true . There are usually 2 grades of drums/rotors availible , cheap/china ones or premium ones.The cheap ones will warp when they get overheated or not torqued properly. Most rotors have enough meat on them to be turned once , some twice , as long as over minimum thickness spec no problem . Most quality repair shops still have brake lathes as do most of the specialty brakes shops , but faster and more profit in selling new rotors. Lot of times rotors from factory are poor quality , Chrysler had lot of problems with rust pits in rotor , looked terrible , the more you turned it the more pits exposed . They still worked fine ,,just looked awful .
Robert in W. Mi.
07-07-2004 11:31:32
The NAPA here still does turns rotors and drums, and also a few other places around here do so too.
Most new cars rotors are so thin to begin with, you can't turn them, so every one stocks new rotors these days.
Robert
Mike (Wi)
07-07-2004 08:51:43
Well, it is only my opinion but I think they have gotten away from turning rotors because later model cars are VERY CHEAPLY BUILT. They thinned the metal and made is softer, so it won't last now.
Consequently, it is not safe to turn them, and nobody wants the liability. It is easier and more profitable for the the suppliers and automakers to force everyone to keep buying new ones.
My mother has been through three sets of rotors in 70,000 miles on her 2000 Buick. Those are AC DElCO parts, and she is NOT hard on brakes.
My newest car is a 91 Cadillac. Now has 170,000 miles on it, and front brakes haven't been touched since 84,000 miles.
Wife has a 99 VW Jetta. Had to replace all four rotors twice now and car has less than 100K on it.
Just my opinion, but the newer stuff is JUNK, and it costs WAY TOO MUCH.
Sorry for the rant.
MAC,IL
07-07-2004 11:29:39
 Re: Re: Brake drums, rotors and lousy parts stores in reply to Mike (Wi), 07-07-2004 08:51:43
Mike: I will agree with your post. Places used to have mechanics, now they are technicians? Anyhow, basically they are just part changers. Take a veh in anymore and you always get stuck with a "new Part" I think GM did have some rotor problems, thin and actually made to be replaced not refinished. I dont know where to place the blame on stuff any more. None of these outfits even if they have a good design wont leave it alone. Like the front wheel drive, wonder why a lot are going back to rear wheel soon. Brakes: Disc brakes have been around for a long time, wonder why the H--- they have not perfected them yet. But again if a guy can buy new every 36 months or when warranty is gone, I suppose you wouldnt have a problem.
Least you wouldnt have to anti up for repairs.
Chris
07-08-2004 10:43:58
 Re: Re: Re: Brake drums, rotors and lousy parts st in reply to MAC,IL, 07-07-2004 11:29:39
Turning a rotor or drum is not as easy as it may seem. The lathe can hurt someone who doesn't know what they are doing. The lathe is an expensive machine to have in every store. I am a tech and I used to moonlight at Advance. Very few of the store 'associates' could operate a lathe correctly. The reason they quit doing it is because they sell those plain, white-box rotors and drums from china. Some are as cheap as 8.99. In the St. Louis area the standard prices for turning were $5 for drums and $6 for rotors. What have you guys paid in the past?
The reason we are called Technicians now is because the car you drive is ten times more complicated than the machine you are typing on. It is no longer possible to keep throwing parts at a vehicle and see what sticks. The era of the 'part changer' is gone. The training is endless. I don't know about the big three not turning rotors. I have cut rotors and drums on brake jobs since I was in tech school. I spent 3 1/2 years at a Chrysler dealer and we cut rotors/drums on EVERY brake job. I have been a technician for 15 years, and since day one, we place the blame for the cars of today firmly on the shoulders of the engineers who design them. The engineers do not think about these vehicles being servicable. They want to pack more power into a smaller box, make it somewhat safe, and last just long enough to keep people from complaining. The thing I have said for years is still true. They only worry about putting 'em together. They don't care about those of us who have to take them apart..... or those that have to pay for the work. A lot of folks think repair shops charge more and more. That isn't the case. Everytime a car gets more advanced, has more goodies, more power, or a sportier look, it takes more time to work on. Since we technicians get paid by the time it takes to do things, it costs more. Thing is, the tech is usually the one getting rode hard and put away wet. We loose our asses on warrenty time. If the customer pays for a particular job, the tech might get paid for eight hours. If the manufacturer gets to pay the the repair under warrenty, the tech may only get paid 4.2 hours to do the same work. It is still the same job, yet nearly half the pay. Believe it or not, the tech isn't getting it as good as you might think. Sorry for the length, kinda got carried away.
Mike
07-07-2004 12:09:39
Mac,
Agree with you as well. I didn't mean to be a dig at GM--I think they are all that way.
They are now making disposable cars and trucks. Everything is disposable--except the PRICE.
They are not a good value in my opinion, and I don't know what to do about it aside from fixing the old stuff and keeping it going.
buickanddeere
07-07-2004 13:39:58
 Re: Re: Re: Re: Brake drums, rotors and lousy part in reply to Mike, 07-07-2004 12:09:39
Today's vehicles get better milage, have better drivability, more power, stop better, steer better, have improved crash protection and don't have rust holes through the body at three years of age. Engines even last 200,000 miles now when 100,000 used to be a near mircle.
Vehicles are better now than they ever where.
Glad to see rear wheel drive coming back. I'd much prefer the feel and have the towing capacity.
Been driving my 87 rear wheel Regal and trucks waiting for something other than a sports car with rear wheel drive.
Mike
07-07-2004 17:34:12
 Re: Re: Re: Re: Re: Brake drums, rotors and lousy in reply to buickanddeere, 07-07-2004 13:39:58
True that cars are better and last longer than 20 years ago, but not 10 years ago.
I have noticed a marked decline in quality of vehicles of just about every make from GM to Volvo, to VW and even Mercedes since about 97.
2004 models as a general rule cost MORE and wear out quicker than 1992 models.
Have you looked at a new Chevy pickup? A friend of mine just bought one. Over $30K for the thing. He says it has 16 different little computers on it, and he is not happy with the slop in the driveline.
There is no way that that thing will be running 20 years from now. (How do you repair 20 year old computers?--You cannot. They are entirely disposable.)
My father's 1990 GMC 1/2 ton is still running good at over 200K miles.
I stand by my statements.
buickanddeere
07-07-2004 20:47:03
 Re: Re: Re: Re: Re: Re: Brake drums, rotors and lo in reply to Mike , 07-07-2004 17:34:12
Have a 95 Jimmy 4x4 which was an excellent truck until 240,000km when it was whacked from behind by someone yapping on their cell phone. Body still looks like new here in winter salt country. Should have traded, burned or pushed it into the lake afterwards. Until three years ago I drove my 1987 Buick Grand National year around. Oiled it about 2 out of three years. Has 460,000 on the original short block and still makes 325+HP with a few aftermarket goodies. Only place rust has occurred is in the "A" pillars and the roof where I didn't oil it. Still a blast to drive from Easter to Thanksgiving. Had a 2002 4x4 1500HD Sierra crew cab. Excellent truck, drove it for a year and it only cost $2000.00 after selling it to the US market. Currently has the same in a 2003 but hanging onto it as the US market for trucks has gone soft. Thoroughly enjoy both Sierra trucks, great power, acceptable mileage, good handling/power. And is 2-1/2+ tons of steel protecting my family. Electronics and electricity are no great mystery. Just trace the blown components and replace it.
bob g ny
07-07-2004 07:09:16
if advance doesnt turn down rotors or drums why would they need a caliper and have the specs for thickness. plus once you cut a rotor it warps quickly anyways...
buickanddeere
07-07-2004 05:08:05
Every rotor I've ever had turned warped within weeks even though it was in spec. I just install new carbon metalic pads and go. The rotor does eventually get thin and finally warp, they don't seem to score with those pads. Even the new rotors warp unless you spend a couple of more bucks and get the premium units. Rear drums are cheap and only do a small percentage of the braking anyways. They last a long time.
Ron
07-07-2004 02:10:27
The big three automakers long ago changed their service manuals to forbid turning rotors/drums. The reasons is liability and cost. The service manuals have specifications for scoring and runout and if these are within spec the part is to be returned to service, if not, they are to be replaced. Some manuals still allow turning truck rotors, especially where the rotor/hub is integral. New rotors for many cars are not much more expensive than the getting the old ones turned. I've seen the made in china ones for as low as $9.
Like the others have said, NAPA and Carquest and some others that cater to mechanics will still turn them for you.
07-07-2004 09:52:07
 Re: Re: Brake drums, rotors and lousy parts stores in reply to Ron, 07-07-2004 02:10:27
Actually the NAPA here won't turn them.
$9 brake rotor? Is it made of steel or tinfoil?
I had not heard that manufacturers had put an end to turning rotors and drums. I wonder why the folks at the parts stores never said anything about that?
The way lawsuits are today, if the makers say don't turn them, I don't blame stores for not doing it.
Ron
07-07-2004 14:43:08
 Re: Re: Re: Brake drums, rotors and lousy parts st in reply to James in North Carolina, 07-07-2004 09:52:07
NAPA stores are independent. Some do, some don't.
Rotors are made from cast iron.
The folks at the auto parts store liklely knew it before you did. That's why they don't turn them.
Yep, lawyers run the world. Sad but true.
Mark
07-06-2004 22:01:07
I don't know Advance but Autozone is a cheap imatation of a parts house. NAPA is still a quality show. Around here the auto machine shops Kragen/Checker and PepBoys still turn drums and rotors. Although I wouldn't buy parts at PepBoys either.
kraigWY
07-06-2004 20:37:39
I can't understand not having calipers anyway, BUT! Anyway Both Napa and CarQuest (the only autoparts stores in town) turn rotors and do a couple of auto repair shops. And the town is only 3000 people.
Having said that I turn my own rotors on a lathe. Had to make a tool holder to cut both sides at the same time. I guess it just depends on where you live.
Chester
07-07-2004 15:27:42
 Re: Re: Brake drums, rotors and lousy parts stores in reply to kraigWY, 07-06-2004 20:37:39
Most people do not do their own repair work, likely the biggest reason nobody turns anything these days. Cost of turning + labour (for RE + RE) equals the cost new ones+ in a lot of cases. My trucks are 80's Dodges and you can still buy new Chinese rotors for $20 ea Cdn. so wouldn't even consider turning any of those. And, those rotors go forever if you use "organic" (probably Asb.)pads and catch them before they reach the rivets.
