Tool Talk Discussion Forum
unsustainable welding current
Ron (Tex)
07-06-2004 13:09:11
My Miller ADAE-200LE protable welder will not sustain an arc when it is set to "automatic idle" mode. I appears that the RPM of the generator drops thereby reducing the volts/amps requirements. (I running at approx 120 Amp DC output). If I set it so that the "automatic idle" switch is "off", the RPM is maintained at approx 3000 rpm and I can maintain the arc.
T_Bone
07-06-2004 19:39:21
 Re: unsustainable welding current in reply to Ron (Tex), 07-06-2004 13:09:11
Hi Ron,
I never used a 200LE but have found that bad or corroded welding lead connections will stop some machines from kicking up from the automatic idle.
T_Bone
Jerry L /az
07-06-2004 13:48:29
With the auto idle on it should idle down. as soon as you strike an arc it should back up to high idle ..... Jer
