Tool Talk Discussion Forum
Paint gun air pressure
Jerry L /az
07-05-2004 18:52:45
I'm looking at some touch up guns, I have a neighbor who does a lot of spray painting he says to stay away from the high pressure guns use a HVLP gun ok I'm looking at a couple that states air pressure at 3-4 bars. what is the unite bar? how many psi does that refer to? thank for help..... ..... Jer
Justin-PA
07-06-2004 08:03:11
 Re: Paint gun air pressure in reply to Jerry L /az, 07-05-2004 18:52:45
3 - 4 bar would be between 43 and 58 psi.
BobCaesar
07-06-2004 07:59:48
If you've got an air supply on hand you might ck out Wanger's softspray HVLP "conversion gun". It uses about 6 to 8 psi & cost around a hundred bucks. You really don't need a HVLP turbine system unless you are doing ultra high class painting.
I've got the Wagner & like it very much!
Jerry L /az
07-06-2004 03:48:40
Thank you for the information ..... ..Jer
Larry E
07-05-2004 19:54:35
I think 1 bar= 14 psi
Charles (in GA)
07-05-2004 20:30:23
 Re: Re: Paint gun air pressure in reply to Larry E, 07-05-2004 19:54:35
If you want to get real picky, my handy dandy unit converter on my Sony handheld, says that 1 bar = 14.5037738 psi
Charles
