Tool Talk Discussion Forum
SHOP-VAC blows
Steve-Maine
07-05-2004 14:20:33
I have had a couple os shop vacs that seems to blow dust out the exhaust. Is thee a brand that doesn't do. I tried to clean out truck and dust got blown right back into trucks. Thanks
Chris
07-08-2004 10:53:06
 Re: SHOP-VAC blows in reply to Steve-Maine, 07-05-2004 14:20:33
I have a Ridgid Vac. It has a large paper air filter inside much like a GM truck. I don't notice any dust. BUT, if your gonna suck up water you have to remove the filter. THEN don't forget to reinstall like I did. That makes a big mess.
ted
07-06-2004 22:02:07
The paper bag type filter tends to let more dust out on startup than the pleated engine type filter. The elcheapo paper bags are really bad.
hjp
07-06-2004 22:01:06
its the filter/get the HEPA RATED one ie,sheet rock dust about $20 at home depot or lowes
Vacs are supposed to suck
07-06-2004 17:35:58
check for damaged filter, or improperly installed filter.
rhouston
07-06-2004 10:59:13
All vacs that use a filter will blow SOME dust out the exhaust when turned on (it's a favorite trick for the Rainbow sales people). if it's constant you need to look at the filter
Ben
07-06-2004 04:32:46
Steve: If you want a vaccumm that won't blow dust when you start it up , get a FEIN vac. IMO I think they are the best on the market. They use two fans in there unit one for sucking and one for cooling the unit off. These unit are almost impossible to burn out due to there efficently to cool the motor. good luck, see link below
rustyfarmall
07-05-2004 18:42:02
Either the filter is defective or the top is not on right. I would suspect the filter first, it is either torn, or not installed properly.
MAC,IL
07-05-2004 15:58:42
Maybe you are overlooking something, I never saw that happen before and have never had that problem.
