Tool Talk Discussion Forum
drained my air compressor, what a mess
Dean Minnesota
07-04-2004 07:42:08
I finally got around to draining my 60 gallon air compressor after buying it new from Menards about 2 1/2 years ago. I relieved the air pressure and then removed the fitting from the bottom of the tank. Only a little bit of water trickled out, maybe a tablespoon or so. I decided to turn the compressor back on to shake any moisture off the inside walls. It starteed trickling out a little more and then a gushher came out. It appears that rust and dust had formed a hard sediment on the bottom of the tank and it wan't until I turned the compressor on and built up pressure which blew out the bottom crust arund the valve anyway that I was able to drain all the water out which made quite a splattering mess for a 5 foot diameter around. It makes me wonder how much crud is still left in the bottom of the tank causing corrossion with no way to get it out.
Dean Minnesota
07-05-2004 05:17:04
 Re: drained my air compressor, what a mess in reply to Dean Minnesota, 07-04-2004 07:42:08
Thanks for the info.
George
07-05-2004 03:38:12
Harbor Freight has an Auto Compressor Drain (HF#46960, Approx $11) that plumbs into where your manual drain goes and lets out a one second squirt of air (and condensate, if there is any) each time the compressor starts or stops. I have had one for two years now and is worth every penny. I have it drain into an old pizza pan and it evaporates before needing to be emptied. (Dean, you will need to clean out the debris in your tank first or you will plug up hte valve.)
Rick
07-04-2004 19:48:52
I just installed another 80 gal compressor after my 15year old unit blew pump. I kept the old tank and plumbed them together now for 160 gal capacity. It is plumbed allthru shop but what I did with the drain plugs was remove them and installed t fittings and plumbed them together with hose and made another hose outlet to use of 50ft with shutoff valve spliced into hose. This really works great at keeping the moisture out of tanks and you have another outlet to use also. My whole unit is in a cabinet insulated for silence so this way of draining really works nice. Rick ps I would always set them up this way now whether single tank or combined tanks
Rick
07-05-2004 03:42:12
 Re: Re: drained my air compressor, what a mess in reply to Rick, 07-04-2004 19:48:52
Sounds like both of your tanks are in parallel feeding one drain hose. The only problem I see is if you have debris in one of your tanks plugging up its drain hole, you won't know it.
Charles (in GA)
07-04-2004 12:12:29
I think the dumbest thing a compressor designer can do it put the drain directly on the bottom. One manufacturer has enough sense to put a tube inside from the bottom up and over to a valve on the side of the tank. Its high enough to get a 5 gal bucket under.
My compressor had the drain on the bottom. I did not want to anchor the unit to the floor, and certainly wasn't going to leave it on the pallet like alot of people do, so I welded up a frame best described as a asterisk (*) Its made of 2x3 1/8 wall tubing that I had on hand, and it is four feet in diameter. At each leg I drilled a 1/2 inch hole squarely thru the legs in a drill press prior to welding it up. Then I welded it, painted it, and bought six adjustable feet with neoprene bottoms and installed in the drilled holes in the legs. The compressor has three feet and I set it on the asterisk frame and drilled for the feet of it to bolt it to the frame.
Lastly, and what brings up this story, is that I installed a galvanized pipe street ell and a 12 inch pipe section and a ball valve, and a barbed fitting with a section of hose on it. Now when I go to drain it, I stick the hose in a 5 gal can with a top, and crack open the ball valve. You could go one better than this and install one of the automatic valves that vents every time the compressor shuts off.
Keep the tank drained, it will not corrode near as much, and should last for years.
Charles
