Stuck Piston pins
Stan
10-08-2000 20:44:22
What do you guys rec for loosening stuck parts? Also how long should we leave them soaking? Thanks.
Steve Hansen
10-10-2000 07:33:50
 Re: Stuck Piston pins in reply to Stan, 10-08-2000 20:44:22
Stan,
Are you sure your wrist pins are stuck? Some wrist pins are pressed in. If your wrist pins are held in place by spring clips or snap rings then they should slide out. The absence of spring clips or snap rings indicates a press fit. Taking them aprart requires a press and fixture. Any automotive machine shop can do this for you. If you are going to bore out your block for larger pistons the machine shop can do this for you at the same time. If however, you are simply going to do a basic ring job there is no need to take the pistons off the rods.
Steve
