Horsepower formula
Jeff D.
10-08-2000 17:41:22
Does anyone know if there is some kind of formula to convert cubic inch displacement to horsepower? Thanks in advance.
Dean
10-09-2000 13:57:41
 Re: Horsepower formula in reply to Jeff D., 10-08-2000 17:41:22
Horsepower = ((torque X RPM)/5252).
Most Otto cycle engines can produce about .75 to 1.0 lb./ft. of torque per cubic inch.
Plug in the # of cubic inches and the engine RPM and you can approximate the horsepower figure.
john d
10-09-2000 06:56:12
There are too many variables to allow this. Horsepower is a measure of how much work the engine can do in a given amount of time. The formula for this needs TORQUE and RPM. Two engines of identical displacement can develop widely different amounts of power. Factors which cause this variation include not only the speed of the engine, but the ratio of bore to stroke, compression ratio, ignition timing, camshaft profile, combustion chamber design, valve and valve seat profile, intake and exhaust port design, intake and exhaust manifold design, carburetion/fuel injection efficiency, and other little "tricks and tweaks" that make incremental differeces. Tractor engines will quite often develop 1 horsepower for every 5 to 6 cubic inches of displacement, sometimes more, sometimes less. Race engines will often develop well over 1 hp per cubic inch. Turbochargers and superchargers can push this much higher.
T_Bone
10-08-2000 20:00:14
Hi Jeff, without digging into one of my engineering books I can give you a SWAG, Scientific Wild A** Guess. I have a tractor with 135ci that puts out 35hp @ PTO. 35/135 =.259 and 135 x .259 = 35hp. Calculate your new ci displacment. Lets say it's 188ci. 188x.259= 48.7 hp, I look up a IH 188ci and it puts out 46.2 @ PTO so it's a pretty close SWAG. Don't know if this will help or not.
T_Bone
Jeff D.
10-09-2000 17:36:52
 Re: Re: Horsepower formula in reply to T_Bone, 10-08-2000 20:00:14
Thanks for your help. I was looking for something to get me in the ball park. This will do just fine. Thanks again.
