Tool Talk Discussion Forum
cutting cultured marble
Mike S
06-30-2004 16:18:43
The local Lowe's has some of this cultured marble counter top that I can get pretty reasonable. How do I cut it the length I need? Can I do it with a circular saw with a special blade? I have one for cutting concrete blocks and another for cutting ceramic tile. Will either one of those work?
alexander neil
12-28-2005 06:54:28
 Re: cutting cultured marble in reply to Mike S, 06-30-2004 16:18:43
How should I do this? Table saw or router?
rogman
07-02-2004 16:59:49
Keep your pinkie finger on your right hand in the air at all times during "cultural marble" cuts.
Mike S
07-02-2004 04:56:56
Thanks for the tips. I have a diamond blade on my Skill HD77 worm drive saw. I would think that would do it. I'll pick up a piece of it on the way home tonight and see how it does.
Mike
Gus
07-01-2004 16:22:06
I cut and install cultured marble tops a lot. I use a diamond blade in a circular saw. Then beltsand if you need a precision fit. Caulk helps to hide the ends/back against walls. The others are right, cut from the back.Dusty.
Dave in Texas
07-01-2004 07:04:15
I just finshed a counter top. They sell a wet table saw for $88. It worked great. The marble is soft and several pieces broke. I had a lot of angles and notches. Cut on the back side.
Ron
06-30-2004 16:44:16
Each product has it's own recommendations for proper cutting tools and techniques. Lowes is happy to advise you too.
Mike S
07-01-2004 04:31:26
 Re: Re: cutting cultured marble in reply to Ron, 06-30-2004 16:44:16
Actually, I asked three different salespeople at Lowes about cutting it and they all said "I dunno" One went so far to say that these things were cast and you could not cut them. So that is my challenge. I will try to lurk the net and see if I can find the answer.
Ron
07-01-2004 04:34:36
 Re: Re: Re: cutting cultured marble in reply to Mike S, 07-01-2004 04:31:26
Try the manufacturer's website or 800#. A very general rule is that a fine tooth carbide blade works well but all the manmade counter top products each come with cutting instructions.
Larry (MO)
07-01-2004 08:26:12
 Re: Re: Re: Re: cutting cultured marble in reply to Ron, 07-01-2004 04:34:36
What Ron said and ...
Very fine tooth carbide blade is the right type. Buy two if you have a lot of cutting to do. Never cut cultured marble with a dull blade. Cut from the back side and use masking tape on the front and back where you plan on cutting. It discourages the cultured marble from crumbling.
