Tool Talk Discussion Forum
HELP- More impt than tractors
Hanovertom
06-29-2004 05:33:03
Help, my sweet corn is in trouble. Pretty sure I'm dealing with a racoon, I have TWO traps set,so it trips the traps, reaches in and eats the bait. SO reset and place blockes on each side, it rolls the block out of the way and eats the bait. Corn has tasseled and silked, and it has pulled several down to test.
Any Ideas?
thanks
Unimog
06-29-2004 19:44:38
 Re: HELP- More impt than tractors in reply to Hanovertom, 06-29-2004 05:33:03
If the area isn't too large and you have electric
power nearby, I've found that a radio with a talk
station keeps the coons and deer out of my garden.
I put it on at dusk and shut it off in the morning
Works very well. I put the radio in a tipped over
plastic trash barrel to keep it out of the weather
51 Pony
06-29-2004 15:57:20
Right, not more important than the tractor, but close. We always kept the coons and skunks out of the sweet corn with a single wire on a good heavy-duty fencer. One with some real juice to it. Put the wire 4-5" above the ground. They test the wire with their nose and don't come back. Stops the deer too, but they tear up the wire running away the first night.
Wayne
06-29-2004 15:30:49
One thing that I found that works by accident, is to water the ground a little bit to make it moist enought so that when you have the little neighbor girl walk barefoot through the mud, a little will stick to here feet. I don't know what it is, but the barefoot prints helps me, maybe it is the human oder left behind. Probably will have to do it several times.
Nolan
06-29-2004 11:43:14
Can't determine what type of trap you're using, or its size, or how your setting it. But whatever the case is, either the trap is wrong or you're setting it wrong.
For racoons, I personally find things like the egg traps or coon cuffs to work well.
Bus Driver
06-29-2004 09:55:47
Check for footprints. If none, make some mud so that footpints will be left. Dogs have been known to pull down and eat corn ears.
ShepFL
06-29-2004 15:59:45
 Re: Re: HELP- More impt than tractors in reply to Bus Driver, 06-29-2004 09:55:47
Amen to that!!
My dogs won't bother the corn while standing but once it is getting picked they are all over it. When shucking we throw them some from time to time (unfilled ears) and they nearly founder on it.
Just can't bring them in for the night as they need to use bathroom at the most late hr. Failure to let them out provides wonderful surprise in the morning to deal with prior to leaving for work :)
ShepFL
06-29-2004 09:15:17
Sounds like coons to me. You better try to get rid of them ASAP as they will bring their buddies. My sons get paid $5.00 a head provided one paw is left on as proof.
Once they find a patch of corn they will destroy it. Deer got most of my beans this yr. so I planted a second time to ensure freezer gets some fresh deer meat :)
I find trapping more effort than a kid with a .22
thurlow
06-29-2004 08:51:44
Don't know what kind of traps you're using, but a live-animal trap.....Havahart type.....of the right size will catch any small animal. When trapping racoons, I bait with flat-can sardines....
Ron
06-29-2004 06:33:09
Nothing is more important than tractors!
But, to answer your question, are you sure you have 'coon traps? All small animal traps are not the same. Next, if he's moving the blocks, silicone glue or tie-wrap them in.
I live in the boonies where garden predation is solved with 6 strand electrified fences. If you think 'coons do damage, you should see what 12 deer can do in one night... or one bear.
Killed 2 coons the other
06-29-2004 14:53:25
 Re: Re: HELP- More impt than tractors in reply to Ron, 06-29-2004 06:33:09
Guess they were the wrong coons. The main thing about dealing with coons it that
they are TUFF. Unless you know that coon is dead
stay back alittle. Coons can hurt you and have been known to kill dogs. Chow dogs may be an
exeption because my chows have killed coons.
I have killed coons with 22s and 410s, if you want
to do that take a pocket of extra ammo, you will
need it. I recomend using something bigger. The last few possoms I killed were with a 38 special
and most of them took more than one shot.
Keeping the grass mowed real good has worked for me. I live next to some wooded land and used to
have all kind of critters coming in the yard to be
killed by my chows. After I saw one too many
snakes I mowed the grass between me and the woods
I use a push mower and even mow up to the trees.
It isnt that much mowing and I am suprised how
much of a difference it makes. Since then nothing
has come in the yard. Coons like trees and if you get to shoot one he
may be in a tree.
tonyoneandonly
