Tool Talk Discussion Forum
Welding cast material --- advise
Richard in Texa
06-24-2004 13:12:32
I broke a pulley on my sickle bar mower. Its made of a cast material with I guess some steel in it because a magnet sticks to it. I've got a new pulley,but the V grooves may be different.
I may need to cut the old belt rings off the old pulley and cut the center section out of the new pulley and have them joined together.
I'm gonna have someone weld it since I have experience with pipe fence only. I have heard you need nickle rods.
What should I ask someone who may potentially weld it so I know he can do it???
RobertTX
06-25-2004 06:51:41
 Re: Welding cast material --- advise in reply to Richard in Texas, 06-24-2004 13:12:32
Richard, I would be very leery of welding any rotating part, especially cast. The problem is the cyclical loading that will be put on the part and the residual stresses left from the welding. It is likely that the weld or area near the weld may fail from fatigue. The result can be flying parts, with absolutely no warning. As the other guys suggested, you can probably buy a new one that fits your application cheaper than you could pay a shop to do the welding and normalizing that should be done on the one you have. Good luck.
T_Bone
06-25-2004 00:05:52
Hi Richard,
You might want to check on sheaves (pulley) made by Browning Mfg as the come in many different diameters for different V belt sizes with a taper insert to lock onto the shaft. I've never been let down finding exactly what I need to fit.
Last one I bought (12yrs) was about $35 for a 10" 2 V belt sheave with a taper insert about $26. So cost may be up there about $90 at todays prices.
From your project discription it sounds more cost effective than having it welded.
T_Bone
george md
06-24-2004 17:53:55
Richard, The site kendall gave you is a good
one . Here is another with much info about
the how and why of cast welding .There are
3 or 4 pages read it all !!!
Welding cast with arc is the worst choice
of types of welding ,oxy/acet weld or brazing
are better choices .
george
Larry E
06-25-2004 19:41:33
 Re: Re: Welding cast material --- advise in reply to george md , 06-24-2004 17:53:55
If proper rod is used and pieces to be welded are ground,pre heated weld small area and peen with chipping hammer or air needle gun.When done put in lime to cool slowly.If too large to put in lime wrap with heat proof blanket.This is better than a brase job.Usually a nickle rod is used.
Kendal
06-25-2004 08:28:02
Good find on welding cast iron. I added it to by bookmarks.
Kendall
06-24-2004 13:23:43
if it IS cast iron, go here:
richard in Texas
06-24-2004 13:29:35
 Re: Re: Welding cast material --- advise in reply to Kendall, 06-24-2004 13:23:43
nice. Thanks
