Hi Liana, No it won't cut that close, well yes it would but won't solve the problem as the saplings will come back next year and the machine will very hard to handle as it digs in the ground to cut and it's going to dull the blade really fast requiring frequent sharping. The better of the two evils is to wait till the grass goes to seed then tractor disc the sapling out and you would have grass next year. Take a hand seed spreader out early next spring and seed to get a good stand. The only other thing I can think of is pull the sapling out with a pick-up with a trailer hitch. Takes two people, one driver and one puller and a 5/16" or heavier chain about 14ft long. Hook one end of chain to the hitch, Back real close to sapling, throw a loop around the base of the sapling with the chain, throw another loop on "top" of the first loop of chain, then the ground person holds onto the other end of the chain tight while the driver pulls the sapling out. The driver has to goose it a tad as it's the sudden jerk that pulls them out. If the chain slips more than a couple foot let go as it didn't "grab" onto the sapling. I never had the chain slip but a couple times and it usually rides up on the stock rather than the chain coming off. You just have to try too see how it works. Over thirty years I can't tell you how many fence posts and small trees I've pulled this way. I was thinking it would save your grass alot better but time consuming. I've also used this method to pull steel posts poured with concrete. If you don't put the bummer right tight against the steel post it will ding the tailgate of the pick-up when you pull them out, if tight it pulls them straight up. It requires no diging around the base of the post or sapling. Here in Arizona I clear sage brush with a yard drag. The ground is very dry here. The drag is two small railroad rails with pipe welded in between then to keep them level. Then another heavy rail lays accross the top of the drag to add weight. When you drag the land you hit the sage brush on about 3ft of one corner of the drag that tears the sage brush out roots and all. Takes about 8 hrs to clean and level 3 acres with the drag. The drag digs in about 6" into the ground and requires a 4x4 for a tow rig on virgin ground. Unless there's someone with a really great tool or idea, I don't see you saving your grass with taking the roots out this year. T_Bone
